Capacitance Dielectric Problem
In summary, a parallel plate capacitor with square metal sheets of side length 30 cm on either side of a sheet of polythene which is 2mm thick has a capacitance of 9.9*10^-10 F m^-1. If a 50V power supply is connected across the plates, the charge on the plates is 4.95*10^-8 and the energy stored in the capacitor is 1.24*10^-6. When the polythene is withdrawn from the capacitor until only half of the space between the plates is occupied by it, the charge on the plates and the energy stored will change depending on whether the polythene is treated as a separate capacitor in series or in parallel.
debwaldy
38
A parallel plate capacitor is constructed by placing square metal sheets of side length 30 cm on either side of a sheet of polythene which is 2mm thick
If the permeability of the polythene is 2.2 *10^-11 F m^-1, what is the capacitance of the system
(ii)If a 50V power supply is connected across the plates, calculate the charge on the plates and the energy stored in the capacitor
(iii) If the polythene is withdrawn from the capacitor until only half of the space bewtween the plates is occupied by it, what is the charge on the plates and the energy stored in this case?
C=Q/V
C= epsi*A/D
E= 1/2*C*V^2
I think i could do part 1 and 2 alright just using the standard equations
(i)C = (2.2*10^-11)*(9.o*10^-2)/(2.0*10^-3) = 9.9*10^-10
(ii)Q= CV
Q= (9.9*10^-10)*50 = 4.95*10^-8
E = 0.5(9.9*10^-10)*(50^2)= 1.24*10^-6
(iii)I don't know what to do for this part, Will the voltage decrease and the charge also?
any tips or hints would be very much appreciated
thanks debs :biggrin:
Well what withdrawing the polythene does is that you can think of the problem as if you had two parallel capacitors, one with polythene, one without. Use the second equation (C = epsi*A/D) to work out the details. Voltage remains constant as it's supplied from a battery.
(simultaneous post)
I'm thinking that the way to solve the latter problem is to treat them as capacitors in series, not parallel, where they add like resistors in parallel.
1/Ceq=d1/Ake+d2/Ae where e =permitivity constant in vacuum d1 and d2 are respective thicknesses and K the dielectric value for the plastic film.
Why would they be in series? The same plates serve for both capacitors.
right but the electric field crosses two distinctly different regions, and the addition of these leads to what I suggested iirc. Might be wrong, however. Its been a long time since I took physics...I should think derivation using gauss' law would not be too difficult in any event. Maybe when I come back I will poke around at this problem some more if no one has commented definitively.
Yeah, that would only be correct if the spacing between plates was greater than 2mm, so the dielectric consisted of both plastic and air.
i thought that was exactly the case, maybe I misread the problem. BTW where does the limit 2mm come from--is this an empirical constant?
The plates are 2 mm apart in the problem.
oh I get it now, i read the problem completely differently, that half the thickness of the dielectric was removed, not that it was now 1/2 air and 1/2dielectric in which case obviously in parallel. Thanks.
FAQ: Capacitance Dielectric Problem
What is capacitance?
Capacitance is a measure of an object's ability to store an electric charge. It is defined as the ratio of the electric charge stored on an object to the potential difference across the object.
What is a dielectric material?
A dielectric material is an insulating material that can be polarized by an applied electric field. This results in a separation of positive and negative charges, creating an electric dipole moment within the material.
What is a capacitance dielectric problem?
A capacitance dielectric problem refers to a situation where a capacitor, which consists of two conductive plates separated by a dielectric material, is used to store electric charge. The problem arises when trying to determine the capacitance value in the presence of a dielectric material.
How does a dielectric material affect capacitance?
A dielectric material increases the capacitance of a capacitor by reducing the electric field between the plates. This is due to the polarization of the material, which creates an additional electric field in the opposite direction, canceling out some of the original field.
What factors affect capacitance in a dielectric problem?
The factors that affect capacitance in a dielectric problem include the permittivity of the dielectric material, the distance between the plates, and the area of the plates. Increasing the permittivity or decreasing the distance between the plates will result in an increase in capacitance, while increasing the area of the plates will result in a decrease in capacitance.
