Capacitors in RC filtering
In summary: This is because the diode only allows current to flow in one direction, resulting in a voltage drop across the diode.
quietrain
655
in AC source, C and R in parallel, why does the capacitor discharge when the voltage across the resistor decrease ?
[PLAIN]http://upload.wikimedia.org/wikipedia/en/thumb/2/27/RC_Parallel_Filter_%28with_I_Labels%29.svg/250px-RC_Parallel_Filter_%28with_I_Labels%29.svg.png
the Vin is a AC source, and the Vout measured is across the resistor.
QUESTION 2
also, why can't i use the multimeter to measure the RMS vale of the ripple voltage across R in this set up?
why do i have to use the oscilloscope?
aren't they the same as long as the multimeter uses true rms calculations?
QUESTION 3
also, if i connect a resistor of about 1kohm in series to a forward bias diode, is it resonable to say that the contact potential of the diode is the voltage across the diode when the voltage of the load first starts to increase?
so since voltage of load increase, current flows through entire circuit, so the voltage across the diode will be the contact potential?
thanks!
Answers:1. The capacitor discharges when the voltage across the resistor decreases because the current flowing through the circuit is inversely proportional to the resistance of the circuit. As the voltage across the resistor decreases, the current through the circuit increases, which causes the capacitor to discharge. 2. You cannot use a multimeter to measure the RMS value of the ripple voltage across R because a multimeter is not designed to measure AC signals. An oscilloscope, on the other hand, can measure AC signals, and is more accurate in measuring the RMS value of a signal. 3. Yes, it is reasonable to say that the contact potential of the diode is the voltage across the diode when the voltage of the load first starts to increase. As the voltage of the load increases, current will flow through the entire circuit, thus causing the voltage across the diode to be the contact potential.
FAQ: Capacitors in RC filtering
What is a capacitor?
A capacitor is an electronic component that stores electrical energy in the form of an electric field. It is made up of two conductive plates separated by an insulating material, called a dielectric.
What is RC filtering?
RC filtering is a type of electronic filter circuit that uses a combination of a resistor (R) and a capacitor (C) to filter out certain frequencies from an input signal. It is commonly used in electronic devices to remove unwanted noise or to shape the frequency response of a circuit.
How does a capacitor work in RC filtering?
A capacitor in RC filtering works by storing electric charge on its plates. When an input signal is applied to the capacitor, it charges or discharges depending on the frequency of the signal. This results in a voltage drop across the capacitor, which helps to filter out certain frequencies from the input signal.
What are the different types of RC filters?
There are two main types of RC filters: high-pass and low-pass. A high-pass filter allows high-frequency signals to pass through while attenuating low-frequency signals. A low-pass filter does the opposite, allowing low-frequency signals to pass through while attenuating high-frequency signals. Other types of RC filters include band-pass and band-stop filters.
What factors affect the performance of a capacitor in RC filtering?
The performance of a capacitor in RC filtering can be affected by several factors, including the capacitance value, the quality of the capacitor, the frequency of the input signal, and the resistance of the resistor used. As the capacitance value increases, the filter becomes more effective at filtering out low-frequency signals. The quality of the capacitor also plays a role in the filter's performance, as higher quality capacitors have lower parasitic effects. The frequency and resistance values also determine the cutoff frequency and attenuation of the filter.
