Car taking a curve, with friction
In summary, a 3500kg truck carrying a 400kg box containing glass with a coefficient of static friction of 0.50 between the box and the truck, a coefficient of rolling friction of 0.03 between the truck's tires and the road, and a coefficient of static friction of 0.95 between the truck's tires and the road can safely take a curve with a 40m radius at a maximum speed of 14m/s without damaging the glass. This is determined by calculating the maximum force of static friction on the truck and the box, taking into account the combined mass of the truck and the box. The coefficient of rolling friction is not a factor in this problem, as it only applies to the tires
Furby
A 3500kg truck is carrying an unsecured 400kg box containing glass.
The coefficient of static friction between the box of glass and the truck is 0.50.
The coefficient of rolling friction between the truck's tires and the road is 0.03.
The coefficient of static friction between the truck's tires and the road is 0.95.
The truck comes to an unbanked curve in the road with a 40m radius.
What is the maximum speed the truck can take the curve without damaging the glass, assuming the glass is damaged should the box slide on the truck, or the truck itself should slide during the curve.
I assume:
a=(v^2)/r
F(friction)=(coefficient)*F(normal)
I'm not completely familiar with the concept, but as I understand it, the car assumes strictly static friction (for my purpose) while attempting the curve, thus the coefficient of rolling friction is completely null, I think.
What I'm not certain with is how exactly the box will react with the truck, being unattached. The only lateral force on the truck attempting the curve is it's static friction which would be:
F(static friction of truck to road)=0.95*((3500kg+400kg)*9.8m/s^2)=36309N
Surely the box's mass would combine with the truck's? But in regards to its being damaged by its own sliding, I assume the same static friction applied to the car is also affecting the box:
F(static friction of box to truck)=0.50*(400kg*9.8m/s^2)=1960N
If it holds true the box will undergo the same force, then you could just ignore the whole system of the car, easily recognizing that maximizing it's friction would completely compromise the box's limits of friction, thus just calculating the box's limits:
1960N=(400kg*v^2)/40m
v=14m/s before the box begins to slide, whereas v=19.29m/s before the car begins to roll.
Thus 14m/s is the maximum speed.
Sorry if it sounds confusing. It doesn't sound very sound to me, either. I guess I'm searching for a confirmation of my logic.
Sounds good to me. A few minor points:
The rolling friction isn't zero--the tires are still rolling--but it's irrelevant for this problem. It's static friction that exerts the sideways force so the truck can make the curve.
At v = 19.29m/s the truck begins to slide outward, not roll. (That's a different problem.)
Good.
Your analysis is mostly correct. The truck will experience a lateral force due to its static friction with the road, which will also be acting on the box of glass. However, the mass of the box will not significantly affect the maximum speed at which the truck can take the curve without damaging the glass. This is because the force of static friction is dependent on the normal force, which is the weight of the object in question. In this case, the weight of the box is relatively small compared to the weight of the truck and will not significantly affect the normal force and therefore the maximum friction force that can be applied.
Your calculation for the maximum speed of the truck is also correct. The maximum speed is determined by the point at which the lateral force due to static friction reaches the maximum friction force that can be applied (in this case, the force of static friction between the truck and the road). Any higher speed would result in the truck sliding and potentially damaging the glass.
One thing to note is that the coefficient of rolling friction may still play a small role in the truck's ability to take the curve without sliding. While it may be negligible compared to the static friction, it could still slightly affect the maximum speed. However, your calculation using only the coefficient of static friction is a good approximation.
Overall, your logic and calculation are sound and your answer is correct. It is important to consider the different types of friction and how they may affect the system when solving problems like this. Great job!
FAQ: Car taking a curve, with friction
How does friction affect a car taking a curve?
Friction plays a crucial role in a car's ability to safely navigate a curve. Without friction, the car's tires would not be able to grip the road and the car would continue moving in a straight line rather than following the curve.
What factors influence the amount of friction on a car taking a curve?
The amount of friction on a car taking a curve is influenced by several factors, including the surface of the road, the condition of the tires, the speed of the car, and the angle of the curve.
How does the speed of a car affect the amount of friction on a curve?
The faster a car is moving, the more difficult it is for the tires to maintain grip on the road. This means that as the speed of the car increases, the amount of friction needed to safely navigate a curve also increases.
What happens if there is not enough friction for a car to take a curve?
If there is not enough friction for a car to take a curve, the tires will not be able to maintain grip on the road and the car will either slide off the road or continue moving in a straight line rather than following the curve. This can result in a loss of control and potentially lead to an accident.
How can a driver adjust their driving to compensate for friction on a curve?
A driver can adjust their driving by slowing down and reducing the angle of the curve. This allows the tires to maintain better grip on the road and reduces the risk of sliding or losing control of the car. Additionally, making sure the car's tires are in good condition and properly inflated can also help improve the amount of friction on a curve.
