Centripetal acceleration and force
In summary, for the cars to remain in contact with the track on a theme park ride with a vertical loop of diameter 20m and a mass of 500 kg each, the minimum speed required is determined by the equation centripetal force + gravity = centrifugal force. To find the maximum reaction of the track, the equation square root of (MgXr) can be used, where M is the mass of the car, g is gravity, and r is the radius of the loop. The acceleration of the car can be calculated using the equation \frac{v^2}{r} or \omega^2r, where v is the speed and \omega is the angular velocity.
Batman121
The cars on a theme park ride each have a mass of 500 kg and travel around a vertical loop of diameter 20m.
What is the minimum speed at which the cars must enter the loop in order to remain in contact with the track and What will then be the maximum reaction of the track?
M=mass
g=gravity
r=radius of loop
i don't know how to work out the mimimum speed required becuase there is no time value or angular acceleration given.
to work out the maximum reaction
Square root of (MgXr)
500X9.81=4905
4905X10=49050
square root of 49050 = 221.472 Newtons (not sure on the forumla though)
Hi Batman121! Welcome to PF! :smile:
Hint: what equation must you apply at the top of the loop for the car to remain in contact with the track? :smile:
the only one i can think of is
centripetal force + gravity has to equal the centrifugal force acting on the cars
That's the one! :smile:
So … putting the numbers in … the minimum velocity, at the top, for a car to remain in contact with the track is … ? :smile:
so it would be mass of 500 X acceleration to get centrigufal force. but i don't know acceleration or how to work it out.
Acceleration of something moving in a circle of radius r with speed v is [tex]\frac{v^2}{r}[/tex] towards the centre of the circle.
That also equals [tex]\omega^2r[/tex], where [tex]\omega[/tex] is the angular velocity, v/r.
FAQ: Centripetal acceleration and force
What is centripetal acceleration and how is it different from regular acceleration?
Centripetal acceleration is the acceleration experienced by an object moving in a circular path. It is different from regular acceleration because it is always directed towards the center of the circle and is responsible for keeping the object moving in a circular path. Regular acceleration, on the other hand, can be in any direction and is caused by a change in speed or direction of motion.
How is centripetal force related to centripetal acceleration?
Centripetal force is the force that is required to keep an object moving in a circular path. It is directly related to the centripetal acceleration, as the force is proportional to the mass of the object and the square of its velocity. The greater the centripetal acceleration, the greater the centripetal force required to keep the object moving in a circle.
What are some examples of centripetal acceleration and force in everyday life?
Some examples of centripetal acceleration and force in everyday life include the motion of a car around a curved road, the rotation of a merry-go-round, and the motion of a satellite orbiting Earth. In all of these cases, there is a centripetal force acting on the object to keep it moving in a circular path.
How is centripetal acceleration and force related to Newton's laws of motion?
Centripetal acceleration and force are both explained by Newton's laws of motion. According to Newton's first law, an object will continue in its state of motion unless acted upon by an external force. In the case of circular motion, the centripetal force is the external force that acts on the object to keep it moving in a circle. Newton's second law states that the force acting on an object is proportional to its mass and acceleration, which applies to centripetal force and acceleration as well.
How does the radius and speed of an object affect its centripetal acceleration and force?
The radius and speed of an object both have a direct impact on its centripetal acceleration and force. As the radius of the circular path decreases, the centripetal acceleration and force increase. Similarly, as the speed of the object increases, so does the centripetal acceleration and force. This can be seen in the formula for centripetal acceleration, where the acceleration is inversely proportional to the radius and directly proportional to the square of the speed.
