Centripitalforce problem (hard)
  • Thread starter trondern
  • Tags
    Hard
In summary, the problem involves a half-cylinder with an item sliding on top of it with a microsmal puff. The goal is to find the angle at which the radius makes with the horizontal axis when the item loses contact with the cylinder surface. To solve this, Newton's 2nd law and the concept of conservation of energy can be used. The normal force on the object will be equal to 0 at the moment it leaves the surface, and the only force acting on it will be its weight.
trondern
Ok, I've been looking around for a answer for this , but haven't found one. So in hope for some help, ill post the problem here:
A pipe has the form as a half cylinder. On the top of the cylinder its placed a item that can slide frictionfree on the cylinder. The cylinder gets a microsmal puff, so the system starts. What angel does the radius make with the horizontal axis in the moment the item loses its contact with the cylindersurface?
Any help solving this would be of great appreciaton from me :shy:
I've tried attacking this with finding an expression for the angle, but it failed. I am having problems really understanding what's causing the item to lose the surfacecontact with the cylinder. I am sure it has something to do with the speed of the item , combined with the angle for the position... I am really drawing a blank here.
This is a classic problem that is in nearly every textbook I've looked through. I'll give you the standard hints:
You must assume that the object leaves the surface at an angle "theta."
What will the normal force on the object be at that moment?
What force (or componant thereof) provides the centripetal force at that moment?
In what way could you determine the speed of the object at that moment?
:bugeye:
Thats what I've been trying to figgur out. There's no examples on it in my book, so its kinda hard to just see it happening.
I was thinking something like this, but unsure what to do with it.. hehe
mg cos(thetta+phi/2)..
seriously ..im drawing a blank here
if the object has just left the surface, can there be a normal force on it?
no, ok. Fn = 0. But I am still confused about what equations to use..
You could use the conservation of energy theorm, or resolve forces radially giving you the normal reaction force. The choice is yours...
Those ..never used them before i think..
How have you solved questions like this in the past?
I haven't solved any questions like this in the past. Thats why its kinda hard for me to get the picture here:)
Here:
Up until the point "theta" the centripetal force is some force component minus the normal force. At "theta" cnetriipetal force is...
Up to thetta it is : sin (thetta) * mg - m*(v^2/R)
at thetta its : sin(thetta)*mg - 0 ?
This is hard:( What do i do with it afterwards?
This is the centripetal force at this point so it is equal to what other formula?
I have no clue...
I know that I'm just repeating, in slightly different words, what Chi Meson has already explained. Nonetheless...
There are only two forces acting on the object: its weight and the normal force of the surface. At the moment in question, when the object is just about to leave the surface, the normal force goes to zero: so the only force acting on the object (and the only force available to provide the centripetal force) is the weight.
You need to do two things:
(1) Apply Newton's 2nd law to forces in the radial direction, remembering that the object has a radial (centripetal) acceleration.
(2) Combine that with an expression relating angle with speed; you can derive one using conservation of energy.
FAQ: Centripitalforce problem (hard)
What is centripetal force?
Centripetal force is the force that acts on an object moving in a circular path, directed towards the center of the circle. It keeps the object in its circular motion and prevents it from flying off in a straight line.
How do you calculate centripetal force?
The formula for centripetal force is Fc = mv^2/r, where Fc is the centripetal force, m is the mass of the object, v is its velocity, and r is the radius of the circular path.
What are some examples of centripetal force?
Some examples of centripetal force include the force that keeps planets in orbit around the sun, the force that keeps a car moving around a curve, and the force that keeps a satellite in its orbit around Earth.
What is the difference between centripetal force and centrifugal force?
Centripetal force is the force that acts towards the center of a circular path, while centrifugal force is the perceived force that appears to push an object away from the center of the circle. Centrifugal force is a result of inertia and does not actually exist as a physical force.
How does centripetal force affect the speed of an object?
Centripetal force does not directly affect the speed of an object. It only changes the direction of the object's velocity, keeping it on a circular path. However, if the centripetal force is increased, the object will move in a tighter circle and therefore have a higher velocity. If the force is decreased, the object will move in a wider circle and have a lower velocity.
