Checking operations over a set
In summary, the operation * is closed under R, but it is not commutative or associative. There is no identity element, which also means there is no inverse for any element in the set. Additionally, when solving for the identity, you should use x * e = x instead of e * x = x. In the specific example given, there is no identity element for the operation x * y = x + 2y - xy.
IKonquer
47
I am trying to the following operation * is closed under R (the real numbers).
x * y = x + 2y + 4
Check commutability - NOT commutative
x * y = x + 2y + 4
y * x = y + 2x + 4
Check associativity - NOT associative
x * (y * z) = x * (y + 2z + 4) = x + 2(y + 2z + 4) + 4 = x + 2y + 4z + 12
(x * y) * z = (x + 2y +4) * z = x + 2y + 4 + 2z + 4 = x + 2y + 2z + 8
Check for identity - NO identity which also means there is no inverse
x * e = x
x + 2e + 4 = x
e = -2
x * (-2) = x + (2)(-2) + 4 = x
(-2) * x = (-2) + 2x + 4 = 2x - 2
Is the work above correct?
Thanks in advance
Yes, it is. You should note in your last that an identity, e, must satisfy both e*x= x and x*e= x. What you have shown, of course, is that x*(-2)= x but [itex](-2)*x\ne x[/itex].
Exactly what are you proving? That the operation forms a group structure over the set, or that the set is closed under the operation? If the last one it is enough to see whether two elements in the set under the operation is still in the set. If the first one you would have to check associativity, existence of an identity, existence of inverses for all elements in the set and at last that the set is closed under the operation.
Wingeer I am trying to show that the operation forms a group structure over the set.
When finding the identity, why should it be x * e = x and not e * x = x? I know I have to check both, but when finding the identity, my book tells me to use x * e = x to solve for the identity.
x * y = x + 2y + 4
x * e -> x + 2e + 4 = x -> e = -2
e * x -> e + 2x + 4 = x -> e = -x - 4
If there is an "x" term when solving for the identity, can I assume that solution is wrong?
Also in another problem when solving for the identity via x * e = x, I found that 2 = x and from e * x = x, I found that e = (-x)/(1-x).
Does that mean there is no identity?
Yes. First use x * e = x to solve for the identity, then you check whether this identity is valid in e * x = x. If it is not, then you have shoved that the operation does not form a group structure on the set, and you're done.
Regarding the other problem, will you write it down so I can see the operation?
However, it does not mean that there is no identity. If the elements in the set are of a form such that every x in that equation gives 2, then you have an identity.
"Yes. First use x * e = x to solve for the identity, then you check whether this identity is valid in e * x = x. If it is not, then you have shoved that the operation does not form a group structure on the set, and you're done."
Right this is what my book tells me to do. But my question is why can't I first use e * x = x instead of x * e = x?
x * y = x + 2y - xy
Check for identity
When solving x * e = x:
x + 2e - xe = x
2e = xe
e = 0 or if e is not equal to 0, then 2 = x.
I'm not sure what to make of x = 2, but e = 0 does not satisfy both x * e = x and e * x = x. So I'm assuming there would be no identity element.
FAQ: Checking operations over a set
What is a "set" in the context of checking operations?
A set is a collection of distinct elements, typically represented within curly braces { }. In the context of checking operations, a set refers to a group of items or values that can be operated on or compared with other sets.
What are some common operations that can be performed on sets?
Common operations on sets include union, intersection, difference, and complement. Union combines all the elements of two sets, intersection finds the common elements between two sets, difference finds the elements that are in one set but not the other, and complement finds all the elements not included in a set.
How do I check if two sets are equal?
To check if two sets are equal, you can use the equals() method in most programming languages. This method compares the elements of two sets and returns true if they are identical.
Can I perform mathematical operations on sets?
Yes, sets can be operated on using mathematical operations such as addition, subtraction, multiplication, and division. However, the exact result may vary depending on the type of operation and the elements in the sets.
How can I efficiently check if an element is in a set?
The most efficient way to check if an element is in a set is to use the contains() method, which returns true if the element is present in the set. This method typically has a time complexity of O(1), making it the preferred method for checking set membership.
