Choice of steam Turbine/Expander?
In summary, the person is considering a turbine as an option for a steam engine that is producing water droplets, and they are looking for a retailer that sells these devices.
Sofokles
Hi!
It's a real problem where we today have a steam throttle and would like to change it for a steam turbine/expander to provide some electricity.
The problem is that the steam is at condensationline:
16 [bar] – T=201,37 [C] – h=2793,65 [KJ/kg]– s=6,4216 [KJ/kg*K]
with an isentropic process over the turbine/expander the steam would get to:
p = 6.6673, v = 0.2693, t = 163, x = 0.9421, h = 2.6395e+003, s = 6.4216
you see that the steam will be wet!
the above gives the Power:
P= (efficiency) * 12 [kg/s] * 154.15 [kJ/kg]= 1849.8 kW
the efficiency will lower the power alot.
Now my question is if someone have solved something similar or know what to choose? Is it possible to use a steam turbine when the steam is this wet? Can a double screw expander be an alternative? We have to regulate the outlet to 163C, will this influence oour choice? What retailers exists?
Thank you very much for your help,
Martin
The steam table I used gives me a different answer:
Inlet conditions:
16 bar(abs) - 201.4 C (sat) - h = 2792 kj/kg
Exhaust
6.667 bar (abs) - 163 C (sat) - h = 2760 kj/kg
Normally, when finding the exhaust state point, we have to use the enthalpy at the saturation line, quality x = 1, not after condensing some of the steam.
This gives a delta h of only 32 kj/kg. Or a theoretical steam rate of 21.88 kg/kw-hr.
With a flow of 12 kg/s or 720 kg/hr, the available energy I calculate is 720 kg/hr / 21.88 kg/kw-hr = 33 kw.
Please correct if someone finds a mistake...
My experience is with steam turbines. You may be hard pressed to get a turbine to do what you want at such a low flow.
As you know, a turbine doesn't actually follow isentropic expansion. A very small turbine might only be 30-55% efficient. The efficiency deficit is realized by the turbine creating less than theoretical power, and this results in a higher than theoretical exhaust temperature. One way to think of it is that all the heat that could be extracted from the steam was not. So if the turbine was exhausting steam at 6.667 bar(abs) at 170 C, it may be necessary to cool it down to saturation temperature somehow.
Wet steam coming into a turbine is not preferred; it would be considered severe duty. Exhausting saturated steam is not unusual. It is best to keep the moisture below 2-3% with these small single stage turbines or else you can start to have bucket erosion problems.
thank you for your answer!
What I have learned is that you can say that the turbine acts like an isentropic process and then in reality like you say it doesnt. If it is like you say that you should fallow the saturation line and delta h is 32 kj/kg. The effect would be 32 kj/kg*12 kg/s=384kW.
after the turbine I would really preffer wet steam than overheated. What the turbine should regulate against is the temperature so if the exhaust steam gets warmer with the losses it might be interesting to lower the pressure even more.
Do you know any company that makes solutions to this kinds of problems?
oops, I made a simple mistake with the steam flow. 12 kg/s = 43200 kg/hr. Which is a big difference in my mind. Sorry for that.
And yes, you're right, the theortical power would be as much as 384 kw as you said. Thanks for the correction, so the theoretical steam rate would be more like 112 kg/kw-hr.
Ok, it seems with this, you may be interested in a desuperheater. I am nowhere near an expert on these devices, but the first link I found on the subject may be a place to start.
http://www.documentation.emersonprocess.com/groups/public/documents/articles_articlesreprints/ag365652.pdf
FAQ: Choice of steam Turbine/Expander?
What is the difference between a steam turbine and a steam expander?
A steam turbine and a steam expander both use steam to generate power, but they operate differently. A steam turbine uses high-pressure steam to rotate blades and produce mechanical energy, while a steam expander uses the expansion of steam to directly generate power without the use of blades.
What factors should be considered when choosing a steam turbine/expander?
Some important factors to consider when choosing a steam turbine/expander include the desired power output, steam pressure and temperature, efficiency, and cost. The type of application and specific requirements of the project should also be taken into account.
What are the different types of steam turbines/expanders?
There are several types of steam turbines/expanders, including impulse turbines, reaction turbines, and axial turbines. Impulse turbines use the impact of high-velocity steam on blades to generate power, while reaction turbines use the reactive force of steam to rotate blades. Axial turbines have blades that are parallel to the axis of rotation.
How does the steam pressure affect the performance of a steam turbine/expander?
The steam pressure directly impacts the power output and efficiency of a steam turbine/expander. Higher steam pressure results in higher power output, but it also requires more complex and expensive equipment. Lower steam pressure may be more cost-effective, but it can also lead to lower efficiency and power output.
What are the advantages and disadvantages of using a steam turbine/expander?
The main advantages of using a steam turbine/expander include high power output, efficiency, and reliability. However, they can also be expensive to install and maintain, and may require a large amount of space. Additionally, steam turbines/expanders are not suitable for all applications and may not be the most cost-effective option in certain situations.
