Classical mechanics: centripetal acceleration
In summary, to stay in a vertical circle, the string must be taut at all times. If I give it just enough speed to get to the top(so when it gets to the top,it's speed is zero)will it fall straight down,or will it just "go back"? It's really hard for me to conceptualize that.
Parallel
42
I need some help with centripetal acceleration.
why when an object is whirling in a vertical circle,it must have a centripetal acceleration larger than 'g' in order for it to get to the top of the circle?
what if I give it just enough speed to get to the top(so when it gets to the top,it's speed is zero)will it fall straight down,or will it just "go back"?
it's really hard for me to conceptualize that
thank you in advance
Take a ball whirling on a string as an example. To maintain a vertical circle, the string must be taut at all times. Analyze the forces acting on the ball when at the top of the circle. To just barely have non-zero tension in the string, what's the minimum speed required according to Newton's 2nd law?
For an object to stay in circular motion it must have a force keeping it from flying away. this is the centrifugal force. for example, in the case of a ball on a string the centrifugal force is equal to the tension on the string. so the C force is non 0 even without gravity. with gravity it just has to be bigger.
If one considers the situation properly, from an inertial reference frame, there is no need to introduce an imaginary centrifugal force; one should use centripetal force in order to avoid confusion.
So if I look at the forces acting on the object when it's at the top of the circle ,I get that: the string is pulling it down
and the gravitational force is pulling it down
so: T+mg = ma
T = m(a-g)
so the acceleration must be greater than 'g' ,if I want the string to be taut!.
this is the centripetal acceleration, and this is why it must be larger than 'g'.
Am I getting this right?
I'm not so sure how to caclulate the minumum speed required.
Your getting close, but the a in your equation above indicates linear acceleration, which is not what you want. The important thing to remember here is that at minimum speed the sum of the forces must be equal to the centripetal force.
so: T+mg = ma
T = m(a-g)
Yes, everything you said is correct.
Use what you know about centripetal acceleration. How does centripetal acceleration relate to speed?
So should I just substitute v^2/r for a?
About the minumum speed,I'm still not getting it.
Yes, use that expression for centripetal acceleration. Since you know the minimum acceleration, you can solve for the corresponding minimum speed.
I got it.
I want to thank you all for your help,thank you.
FAQ: Classical mechanics: centripetal acceleration
What is centripetal acceleration?
Centripetal acceleration is the acceleration experienced by an object moving in a circular path. It always points towards the center of the circle and is caused by the centripetal force acting on the object.
What is the formula for calculating centripetal acceleration?
The formula for calculating centripetal acceleration is a = v²/r, where a is the centripetal acceleration, v is the velocity of the object, and r is the radius of the circular path.
How is centripetal acceleration different from tangential acceleration?
Centripetal acceleration is the acceleration towards the center of the circle, while tangential acceleration is the acceleration along the tangent of the circle. In other words, centripetal acceleration changes the direction of an object's velocity, while tangential acceleration changes the magnitude of the velocity.
What causes centripetal acceleration?
Centripetal acceleration is caused by the centripetal force acting on an object. This force can be provided by various sources, such as tension in a string, gravitational force, or friction.
How does centripetal acceleration relate to Newton's laws of motion?
Centripetal acceleration is directly related to Newton's first law of motion, also known as the law of inertia. This law states that an object will continue moving in a straight line at a constant speed unless acted upon by an external force. In the case of circular motion, the centripetal force acts as the external force that causes the object to accelerate and change its direction.
