Classical mechanics - small movements around equilibrium
In summary: I know this. That's one of the reasons why I don't understand the question. Why would anybody define something like that?The question does not define that.The question says that ##d < A##, which is not the same as ##\frac d A < 1##.
skrat
748
Two cylinders, that can rotate around their vertical axis, are connected with a spring as shown in the picture. Moment of inertia ##J## is the same for both and they also have the same radius ##R##. Distance between the axes is ##L##. Spring with constant ##k## is ##d## long (not deformed). Also note that ##d<L-2R##. Describe small movements of the system.
Let's say that we will measure the rotation of left cylinder with ##\varphi ## and rotation of the right one with ##\vartheta ##.
The kinetic energy is than ##T=\frac{1}{2}J(\dot{\varphi }^2+\dot{\vartheta }^2)##
Now let's use notation ##\eta =\begin{bmatrix}
\varphi \\
\vartheta
\end{bmatrix}##, therefore kinetic energy is ##T=\frac{1}{2}\dot{\eta }^T \tilde{T}\eta ## where ##\tilde{T}=\begin{bmatrix}
1 & 0\\
0& 1
\end{bmatrix}##.
Now for kinetic energy we have to find out how much the spring deforms. Let's take a closer rook at the left cylinder:
The deformation here is ##x_1=R(1-cos\varphi )##. Using taylor expansion around equilibrium state which is ##\varphi =0## tells me that ##x_1=R(1-(1-\frac{1}{2}\varphi ^2))=\frac{R}{2}\varphi ^2##
The same goes for the other side, therefore ##x_2=\frac{R}{2}\vartheta ^2##
So potential energy of the system is ##V=\frac{1}{2}k(x_1+x_2)^2=\frac{kR^2}{8}(\varphi ^2+\vartheta ^2)^2##.
Now what worries me is that there is no way (or at least I don't see it) to write that last expression for ##V## using vector ##\eta ##.
Why do I want to do that? Because using ##det(V-\omega ^2T)=0## will tell me everything I need to know about this system.
Where did I get it wrong?
You have left out the key things that cause the motion of the system.
The displacement of the end of the spring is not just ##x_1##, but also ##y_1 = R\sin\varphi##.
Also the spring has an initial potential energy, because it is stretched between the cylinders. The initial stretch is ##L - 2R - d##. When the system moves the length of the spring changes from ##L - 2R## to ##\sqrt{(L -2R + x_2 - x_1)^2 + (y_2-y_1)^2}##.
Since the question says the displacements are small, you can approximate everything to first order in ##\varphi## and ##\vartheta##.
hmmm... Ok, if I approximate everything to first order, than
##x_1=R(1-cos\varphi )\doteq 0## and also ##x_2=R(1-cos\vartheta )\doteq 0## are both ##0##?
##y_1=Rsin\varphi \doteq R\varphi ## and ##y_2=Rsin\vartheta \doteq R\vartheta ##.
Than the deformation of the spring is ##\Delta L= \sqrt{(L-2R+(x_1+x_2))^2+(y_2-y_1)^2}-(L-2R)##. (I think that's what you meant and that ##-x_1## is just a typo. right?
If yes, than ##\Delta L= \sqrt{(L-2R+(x_1+x_2))^2+(y_2-y_1)^2}-(L-2R) \doteq (L-2R)(1+\frac{1}{2}\frac{R^2}{(L-2R)^2}(\varphi -\vartheta )^2)-(L-2R)=\frac{R^2}{2(L-2R)}(\varphi -\vartheta )^2##
Where I can't see how this helps me since ##V=\frac{1}{2}k(\Delta L)^2##
I was taking ##x_1## and ##x_2## positive to the right, and ##y_1## and ##y_2## positive up.
The sign convention doesn't matter so long as you are consistent, of course. Be careful about the signs of the ##y##'s and the angles!
No, the spring is stretched initially. If the length increases by ##\Delta L##, the strain energy changes from ##\frac 1 2 k (L - 2R - d)^2## to ##\frac 1 2 k (L - 2R - d + \Delta L)^2##.
You've lost me. I have come so far:
Initial stretch: ##s_0=(L-2R)-d##
For rotation ##\varphi ## and ##\vartheta ## the length of the spring changes for ##\Delta L=\sqrt{(L-2R)^2+R^2(\varphi - \vartheta )^2}-(L-2R)##
Than the total stretch is
##s=s_0+\Delta L=(L-2R)-d+\sqrt{(L-2R)^2+R^2(\varphi - \vartheta )^2}-(L-2R)=\sqrt{(L-2R)^2+R^2(\varphi - \vartheta )^2}-d##.
If I put this in ##V=\frac{1}{2}ks^2=\frac{1}{2}k(\sqrt{(L-2R)^2+R^2(\varphi - \vartheta )^2}-d)^2## I get all sorts of nasty things where the most horrible part is that I don't get rid of that sqrt...
Let ##A = L - 2R## to simplify the algebra a bit.
The length of the spring at an arbitrary position (assuming the angles are small) is ##\sqrt{A^2 + R^2(\varphi - \vartheta)^2}##.
The unstretched length was ##d##, so the strain energy is ##\frac k 2 \left[ \sqrt{A^2 + R^2(\varphi - \vartheta)^2} - d\right]^2##.
##V = \frac k 2\left [A^2 + R^2(\varphi - \vartheta)^2 - 2d\sqrt{A^2 + R^2(\varphi - \vartheta)^2} + d^2\right]##.
The constant terms in ##V## don't matter.
##\frac k 2 R^2(\varphi - \vartheta)^2## is a nice quadratic form already.
The remaining term is ##-kd\sqrt{A^2 + R^2(\varphi - \vartheta)^2}
= -kdA\sqrt{1 + (\frac R A)^2(\varphi - \vartheta)^2}##.
Expand the square root to first order using the Binomial theorem (since the angles are small) and you get another constant, and another nice quadratic form.
Jup, that makes much more sense than my notes. I will try tu use the same notation as you did.
##V = \frac k 2\left [A^2 + R^2(\varphi - \vartheta )^2 - 2d\sqrt{A^2 + R^2(\varphi - \vartheta)^2} + d^2\right]##
if we forget about the constant terms
##V = \frac k 2 R^2(\varphi - \vartheta )^2 - kd\sqrt{A^2 + R^2(\varphi - \vartheta)^2}=##
##= \frac k 2 R^2(\varphi - \vartheta )^2 - kdA \sqrt{1 + (\frac R A)^2(\varphi - \vartheta )^2}=##
##= \frac k 2 R^2(\varphi - \vartheta )^2 - kdA(1 + \frac 1 2 (\frac R A)^2(\varphi - \vartheta )^2)##
again forgetting about constants leaves me with
##V=\frac k 2 R^2(\varphi - \vartheta)^2 -\frac{kdR^2}{2A}(\varphi - \vartheta)^2=##
##=(\varphi - \vartheta)^2(\frac k 2 R^2-\frac{kdR^2}{2A})## for less writing let's say that ##C=\frac k 2 R^2-\frac{kdR^2}{2A}##
so finally
##V=C(\varphi ^2-2\varphi \vartheta + \vartheta ^2)##
Does this sound ok?
That looks good to me.
If you write the constant as ##\frac k 2 R^2(1 - \frac d A )##, you can see why the question said that ##d < A##. :smile:
Actually, I think there are some terms missing from V. If you keep the ##x## displacements, the length of the spring is ##\sqrt{(A + \frac R 2 (\varphi^2 + \vartheta^2))^2 + R^2(\varphi - \vartheta)^2}##.
If you go through the same process as before, that will give some more second order terms in ##\varphi## and ##\vartheta##, for example ##AR(\varphi^2 + \vartheta^2)##.
The terms in ##\varphi## and ##\vartheta## higher than second order can be ignored.
Huh, I agree.
I did some calculations, and hopefully you won't find any mistakes:
##x_1=\frac 1 2 R\varphi ^2## and ##x_2=\frac 1 2 R\vartheta ^2## and
##y_1=R\varphi ## and ##y_2=R\vartheta ##
The total stretch of the spring is than ##s=s_0+\Delta L##
##s=(A-d)+(\sqrt{[A+\frac R 2 (\varphi ^2+ \vartheta ^2)]^2+R^2[\varphi -\vartheta ]^2}-A)=##
##=\sqrt{[A+\frac R 2 (\varphi ^2+ \vartheta ^2)]^2+R^2[\varphi -\vartheta ]^2}-d##.
Now ##s^2=[A+\frac R 2 (\varphi ^2+ \vartheta ^2)]^2+R^2[\varphi -\vartheta ]^2+d^2-2d\sqrt{[A+\frac R 2 (\varphi ^2+ \vartheta ^2)]^2+R^2[\varphi -\vartheta ]^2}=## (In every step possible I will simply forget about all the constants)
##=AR (\varphi ^2+ \vartheta ^2)+R^2[\varphi -\vartheta ]^2-2d\sqrt{A^2[1+\frac{R}{2A}(\varphi ^2+ \vartheta ^2)^2+\frac{R^2}{A^2} (\varphi -\vartheta )^2]} =##
##=AR (\varphi ^2+ \vartheta ^2)+R^2[\varphi -\vartheta ]^2-2dA(1+\frac 1 2[\frac{R}{2A}(\varphi ^2+ \vartheta ^2)^2+\frac{R^2}{A^2}(\varphi -\vartheta )^2])=##
##=AR (\varphi ^2+ \vartheta ^2)+R^2[\varphi -\vartheta ]^2-\frac{dR}{2}(\varphi ^2+ \vartheta ^2)-\frac{dR^2}{A}[\varphi -\vartheta ]^2##
Using ##C=AR-\frac{dR}{2}## and ##D=R^2-\frac d A R^2##
##s^2=C(\varphi ^2+ \vartheta ^2)+D[\varphi -\vartheta ]^2##
So finally ##V=\frac 1 2 k[\varphi ^2(C+D)-2\varphi \vartheta D +\vartheta ^2(C+D)]## which is the same as
##V=\frac 1 2 k \eta ^T\begin{bmatrix}
C+D & -D\\
-D&C+D
\end{bmatrix}\eta##Finally I can start calculating ##det(V-\omega ^2 T)=det(V-\frac{J\omega ^2 }{k}T)=0## where ##\omega _k^2=\frac k J##.
If everything is ok, I get two eigenvalues of the system: ##\frac{\omega ^2}{\omega _k^2}=\lambda=C+D\pm D## and accordingly two eigen vectors that describe possible movements of my system
## \eta_1=(1,1)## and ##\eta _2=(1,-1)## as expected.
FAQ: Classical mechanics - small movements around equilibrium
What is classical mechanics?
Classical mechanics is the branch of physics that studies the motion of objects under the influence of forces. It is based on the laws of motion and gravity formulated by Sir Isaac Newton in the 17th century.
What are small movements around equilibrium?
Small movements around equilibrium refer to the motion of an object that is close to its stable or resting position. These movements are usually small and can be described using linear equations of motion.
How do you calculate small movements around equilibrium?
To calculate small movements around equilibrium, you can use the equations of motion such as Newton's second law and Hooke's law. These equations take into account the forces acting on the object and its displacement from equilibrium.
What are some real-life examples of small movements around equilibrium?
Some real-life examples of small movements around equilibrium include the motion of a pendulum, the vibrations of a guitar string, and the bouncing of a basketball. These movements can be described using classical mechanics.
How is classical mechanics useful in everyday life?
Classical mechanics is useful in everyday life as it helps us understand and predict the behavior of objects and systems around us. It is used in the design of structures, vehicles, and machines, and also plays a crucial role in fields such as engineering, astronomy, and sports.
