Combinatorics: Complementary Pair
In summary, the phrase "contains one of each complementary pair of sets" refers to a set of two subsets, one of which is the complement of the other, with no common elements. This is important in the context of intersecting families, as it limits the number of elements that can belong to the family in order for it to remain intersecting.
Robben
166
My book repeatedly uses the phrase "contains one of each complementary pair of sets" and I am wondering what do they mean by that exactly?
None
For example, when it proves that an intersecting family of subsets of ##\{1,...,n\}## satisfies ##|F|\le2^{n-1},## it says the ##2^n## subsets of ##X## can be divided into ##2^{n-1}## complementary pairs ##\{A,X \A\}##.
I am not sure what the mean by complementary pairs when referring to an intersecting family.
None
The notation {A,X\A} tells you what they mean by complementary pairs. Each pair consists of a subset A and its complement X\A (the set of all elements of X that aren't in A). The sets A and X\A have empty intersection. So if F is an intersecting family of sets then for each pair you can select at most one of A and X\A to belong to F. If you pick both then F is not intersecting. So the number of elements in F is less than or equal to the number of complementary pairs.
Likes Robben
Thank you very much for clarifying.
FAQ: Combinatorics: Complementary Pair
What is a complementary pair in combinatorics?
A complementary pair in combinatorics refers to two elements or events that together make up a complete set. In other words, when these two elements are combined, all possible outcomes are covered.
How do you determine the number of complementary pairs in a set?
The number of complementary pairs in a set can be determined by using the formula n(n-1)/2, where n is the number of elements in the set. This formula is based on the fact that each element can be paired with every other element except for itself, resulting in n-1 pairs. Then, to account for the fact that each pair can be reversed, we divide by 2.
Can a set have more than one complementary pair?
Yes, a set can have more than one complementary pair. In fact, the number of possible complementary pairs in a set increases as the size of the set increases. For example, a set with 5 elements can have 10 possible complementary pairs.
How are complementary pairs used in probability and statistics?
In probability and statistics, complementary pairs are used to calculate the probability of an event not occurring. This is done by subtracting the probability of the event from 1. For example, if the probability of an event A is 0.7, then the probability of the complementary event A' (not A) would be 1-0.7=0.3.
Are there any real-world applications of complementary pairs?
Yes, complementary pairs have various real-world applications, such as in genetics, where dominant and recessive traits are considered complementary pairs. They are also used in coding theory to check for errors in data transmission, and in game theory to analyze strategic interactions between players.
