Commutation of squared angular momentum operators
In summary, the conversation discusses trying to prove the commutativity of operators in a general way, specifically the commutators of L^2 and L_i^2. The conversation provides a hint and solution to the proof, utilizing the fact that L^2 can be written as the sum of L_i^2.
jorgdv
29
Hello there. I am trying to proove in a general way that
[Lx2,Lz2]=[Ly2,Lz2]=[Lz2,Lx2]
But I am a little bit stuck. I've tried to apply the commutator algebra but I'm not geting very far, and by any means near of a general proof. Any help would be greatly appreciated.
Thank you.
Hint: [itex]L^2 = L_x^2 + L_y^2 + L_z^2[/itex]
Of course! We can show ## [L^2,L_i^2]=0 ## for ## i \in \{x,y,z\} ##
so
## [L_x^2,L_i^2]+[L_y^2,L_i^2]+[L_z^2,L_i^2]=0 ##, and for ## i=z ## and ## i=x## we have the equalities.
Thank you very much for the hint, I should have seen that sooner
FAQ: Commutation of squared angular momentum operators
What is the commutation of squared angular momentum operators?
The commutation of squared angular momentum operators is a mathematical operation that determines the relationship between two operators that represent the angular momentum of a system. It is used to calculate the uncertainty in the measurement of angular momentum and to understand the dynamics of a system.
Why is the commutation of squared angular momentum operators important?
The commutation of squared angular momentum operators is important because it is a fundamental concept in quantum mechanics. It helps us understand the properties of angular momentum and its relationship with other physical quantities. It is also used in various applications, such as in the study of atomic and molecular structure.
How is the commutation of squared angular momentum operators calculated?
The commutation of squared angular momentum operators is calculated by using the commutator, which is a mathematical operation that determines the difference between the product of two operators and the product of the same operators in reverse order. This commutator is then squared to obtain the commutation of squared angular momentum operators.
What is the physical significance of the commutation of squared angular momentum operators?
The commutation of squared angular momentum operators has physical significance because it helps us understand the uncertainty in the measurement of angular momentum. It also determines the compatibility of two operators and whether they can be measured simultaneously. Additionally, it is used to derive important properties of angular momentum, such as its quantization.
Can the commutation of squared angular momentum operators ever equal zero?
Yes, the commutation of squared angular momentum operators can equal zero in certain cases. This means that the two operators commute, which indicates that they are compatible and can be measured simultaneously. However, this is not always the case and the commutation of squared angular momentum operators can also have non-zero values, indicating that the operators do not commute and have uncertainty in their measurement.
