Composition of functions domains
In summary, the domain of f(g(x)) is not always the intersection of the domains of f(x) and g(x). It depends on the range of g. However, the domain of f(g(x)) will always be a subset of the domain of g(x) that is also in the domain of f(x). The function f o g has the same domain as g, which is typically all real numbers. The domain of f may be more narrow, but f o g will still have the same domain as g.
bcheero
Is it always true that the domain of f(g(x)) is the intersection of the domains of f(x) and g(x)?
I've been having trouble with this and this answer would make me fully understand this concept.
Thanks to everyone!
Mathematics news on Phys.org
It depends on the range of g. If the range of g is contained within the domain of f, then the domain of g is the domain of f(g(x)). If the range of g is not contained, then the part of the range outside is cutoff, inducing a cutoff in the useful domain of of g, i.e. that which ends up as the domain of f(g(x))
Thanks to everyone!
No, it is not always true. In fact it is seldom true. What is true is that the domain of f(g(x)) is that subset of the domain of g such that g(x) is in the domain of f(x).
The domain is simply the set of values your function can accept as input.
The function f o g has the same domain as g which we can pretty safely assume to be all the real numbers.
The domain of f might be more narrow, but f o g has the same domain as g.
I can provide a response to this question. The statement "the domain of f(g(x)) is the intersection of the domains of f(x) and g(x)" is not always true. In fact, it depends on the specific functions f(x) and g(x) being used.
To understand this concept better, let's first define what a domain is. The domain of a function is the set of all possible input values for which the function is defined. For example, if we have a function f(x) = x^2, the domain is all real numbers because we can square any real number and get a result. However, if we have a function g(x) = 1/x, the domain would be all real numbers except for 0, since we cannot divide by 0.
Now, when we compose two functions, f(g(x)), we are essentially plugging in the output of g(x) into f(x). In other words, the output of g(x) becomes the input of f(x). So, the domain of f(g(x)) would depend on the domain of g(x) and also the range of g(x), since that would be the input for f(x).
Let's look at an example to better understand this. Suppose we have f(x) = √x and g(x) = 1/x. The domain of f(x) is all non-negative real numbers, while the domain of g(x) is all real numbers except for 0. Now, when we compose these two functions, f(g(x)), we get f(g(x)) = √(1/x). In this case, the domain of f(g(x)) would be all positive real numbers except for 0, since we cannot take the square root of a negative number.
From this example, we can see that the domain of f(g(x)) is not always the intersection of the domains of f(x) and g(x). It is important to carefully consider the domains of each individual function when composing them, as it can greatly impact the resulting domain of the composition.
I hope this explanation helps you better understand the concept of composition of functions domains. If you have any further questions, please feel free to ask.
Related to Composition of functions domains
What is the definition of a domain in the composition of functions?
The domain of a composition of functions is the set of all possible input values for the combined function. It is determined by the domains of the individual functions involved in the composition.
What are the rules for determining the domain of a composition of functions?
The domain of a composition of functions is determined by the following rules:
  • The domain must be a subset of the domains of the individual functions involved.
  • The domain must include all values that can be obtained by applying the input values to the individual functions in the composition.
  • The domain must exclude any values that result in undefined or imaginary outputs.
How do you find the domain of a composition of functions algebraically?
To find the domain of a composition of functions algebraically, you can use the following steps:
  1. Identify the individual functions involved in the composition.
  2. Determine the domains of each individual function.
  3. Find the intersection of the domains of the individual functions. This will be the domain of the composition of functions.
Can the domain of a composition of functions be infinite?
Yes, the domain of a composition of functions can be infinite. This can happen when the domains of the individual functions involved are infinite and there are no restrictions on the inputs to the composition.
What happens if the domain of a composition of functions is empty?
If the domain of a composition of functions is empty, it means that there are no possible input values that can be applied to the composition. This could happen if the domains of the individual functions do not overlap or if there are restrictions on the inputs to the composition. In this case, the composition of functions is undefined.
