Composition of Integrable functions - An attempt -
In summary, the conversation discusses finding an integrable function g(x) such that the composition of g and f is not integrable. The attempt at a solution presents a function g(x) = nx for all n in N, but the individual discussing the problem is unsure if this is the correct solution. They clarify that h(x) is not differentiable and mention that their previous objection was based on considering Lebesgue integrals instead of Riemann integrals. They continue to discuss the properties of h(x) and request further clarification on the correct solution.
michonamona
122
Consider the following functions:
Modified Dirichlet Function
f(x) = 1/n if x=m/n of lowest forms, and f(x) = 0 if x is irrational
find an integrable function g(x) such that the composition of g and f is NOT integrable
Let g(x) = nx for all n in N (natural numbers)
then
h(x) = g(f(x)) = n(1/n) = 1 if x is rational, and h(x) = g(f(x))= n(0) = 0 if x is irrationalMy g(x) is apparently incorrect. Can anyone tell me why?
I appreciate your help,
M
note: I already know the correct answer, I just need to confirm that the g(x) I came up with is incorrect.
I don't understand the function definition. Is it a function of both n and x, or what?
The other problem is that h(x) = 1 for x rational and 0 for x irrational IS integrable. The integral is zero.
Thank you for your reply, excuse me for being unclear. The function I meant to have is:
[tex] g_{n}(x)=nx \;\forall \; n \in N [/tex]
So this is a linear function that's a ray from the origin. It is also getting steeper as [tex]n\rightarrow\infty[/tex]
To address your other question, h(x) IS NOT differentiable. The upper sums and lower sums will never meet for any partition P.
Thank you,
M
OK, but that's a family of functions, not a single function. How are you composing it with f to obtain h?
I assume you mean integrable, not differentiable. (Though it's certainly not differentiable.) Sorry, I assumed we were talking about Lebesgue integrals, not Riemann integrals. That function is a great example of one that is Lebesgue integrable, but not Riemann integrable.
So good, that removes my 2nd objection. If you can come up with a single function g such that h(x) = g(f(x)) then that will indeed solve the problem. But I don't see how your g (or rather, family of g's) works.
FAQ: Composition of Integrable functions - An attempt -
What is the definition of an integrable function?
An integrable function is a mathematical function that can be represented by a finite number of elementary functions, such as polynomials, trigonometric functions, and exponential functions, and can be integrated over a given interval to obtain a definite integral.
How is the composition of integrable functions defined?
The composition of integrable functions refers to the combination of two or more integrable functions to form a new function. This is achieved by substituting one function into another, resulting in a new function that can also be integrated.
What is the significance of studying the composition of integrable functions?
The composition of integrable functions plays an important role in various areas of mathematics, such as calculus, differential equations, and mathematical analysis. It allows for the simplification and evaluation of complex integrals and helps in solving mathematical problems that involve multiple functions.
Are there any limitations to the composition of integrable functions?
Yes, there are certain limitations when it comes to composing integrable functions. One major limitation is that the composition of two integrable functions may not always result in an integrable function. This is known as the composition condition, and it must be satisfied in order for the resulting function to be integrable.
Can the composition of integrable functions be used in real-world applications?
Yes, the composition of integrable functions has many real-world applications, particularly in physics and engineering. It is used to model and solve problems involving motion, heat transfer, and other physical phenomena. It also has applications in economics, finance, and other fields that require mathematical modeling and analysis.
