[Concept] Why is potential 0 when electric field isn't?
In summary, a charged particle creates an electric field, which affects the potential energy of nearby objects.
Sean1218
86
Say you have a rectangle with -Q charges at top left and bottom left corners, and +Q charges at top right and bottom right corners.
Any point along a horizontal line in the middle will have electric field going to the left, but any point along this line will have a potential of 0. I've been trying to understand this, but having trouble I get that potential is 0 because any point along this line will be equidistant from the two -Q and equidistant from the two +Q.
I think this stems from a lack of understanding of how work and potential (and potential energy) works in an electric field.
It is the gradient in potential that determines the electric field. If the potential is zero at some location but non-zero at some nearby location, there will be an electric field as a result of that potential difference. So in general you want to think about the electric field as resulting from differences in potential. This is similar to how a difference in potential generates a force in mechanics. If the potential is uniform everywhere (even if it's non-zero) there is no force.
Would you say that it is wrong to say: a presence of charge creates an electric field... And traveling within that electric field, we will see a change in potential as long as we don't just travel perpendicular to the field lines.
Don't you travel perpendicular to the field lines along the line where the potential is zero?
ehild
I don't think there is any reason why we would need to... or a charged particle either. We could force a particle along that line and ask some questions about it though.
FAQ: [Concept] Why is potential 0 when electric field isn't?
What is potential in relation to electric fields?
Potential is a measure of the energy difference between two points in an electric field. It is a scalar quantity and is measured in volts (V).
Why does potential become 0 when the electric field is not present?
When there is no electric field present, there is no force acting on a charged particle. This means that the particle has no potential energy and therefore the potential at that point is 0.
How does potential relate to the strength of an electric field?
The potential is directly related to the strength of an electric field. The stronger the electric field, the greater the potential difference between two points in that field.
Why is potential 0 at infinity in an electric field?
At infinity, the strength of an electric field becomes negligible. This means that there is no force acting on a charged particle and therefore it has no potential energy. As a result, the potential at infinity is 0.
Can the potential be negative in an electric field?
Yes, the potential can be negative in an electric field. This occurs when the electric field is directed from a point of higher potential to a point of lower potential. In this case, the potential decreases in the direction of the electric field and becomes negative.
