Square47
- 4
I'm in a math class reading Einstein's original paper "On the Electrodynamics of Moving Bodies," from 1905.
I'm stuck in Section 8, "transformation of the energy of light rays." We're basically trying to show that that Placnk's constant is Lorentz invariant- if anyone has an easy way of deriving this, that would help too.
So far, we have the equation for the relativistic doppler effect: When a moving system k moves parallel to a wave of light relative to a stationary system K, the equation for frequency is
nu'/nu = squrt[(1-v/c)/(1+vc)]
where nu is the frequency of light from stationary system K and nu' is the frequency of light from moving system k, and v is the speed of the moving system k relative to the stationary system K. When
I take this equation to mean that the frequency increases when k moves with -v (taking the velocity of light in the positive direction) and decreases when v is positive. The first case is blue shift, the second red.
This is the first time that the direction of the velocity of system k has mattered for relativistic effects. This makes sense for the doppler effect, because one direction is red shift and the other is blue shift. But I don't see why the direction would matter for energy transformations.
More specifically, the energy in a volume containing light is proportional to the light's amplitude times the volume. If E is energy, A is amplitude, and S is volume (and variable's with an apostrophe are the measured magnitudes in the moving k system), then E'/E = A'^2(S')/(A^2(S)).
Einstein finds that A'^2/A^2 = (1-v/c)/(1+v/c). It appears therefore that, like the frequency, the amplitude increases when system k moves in the opposite direction of light. Why is that?
What's worse, the volume enclosing the light undergoes Lorentz contraction. Einstein assumes that the volume is a sphere moving along with the light as viewed in system K, and applies the Lorentz transformations to find the volume as viewed from system k. I follow his derivation, and it leads to a ratio of the volumes S'/S = sqrt ((1+v/c)/(1-v/c)), the reciprocal of the frequency transformation. Shouldn't this mean that the volume expands when k moves in the same direction as the light, and contracts when k moves in the opposite direction of the light (relative to K)? But I thought Lorentz contraction doesn't depend on direction, only on the velocity.
If anyone has an easy way to think about this, that would be immensely helpful. I hope the equations are readable.
