Confused about this Optics problems Solution
In summary, the conversation discusses the Lick Observatory's large refracting telescope, with an aperture diameter of 36 in. and a focal length of 56 ft. The goal is to determine the radii of the first, second, and third bright rings surrounding the Airy disc in the diffraction pattern formed by a star on the focal plane of the objective. The equations \frac{\pi}{\lambda}Dsin\theta=\gamma and r=f \theta are mentioned, with the latter being used to calculate the radii. The conversation also mentions the use of a wavelength of 550nm, which is a common choice for visible light.
Xyius
508
The Lick Observatory has one of the largest refracting telescopes, with an aperture diameter of 36 in. and a focal length of 56 ft. Determine the radii of the first, second, and third bright rings surrounding the Airy disc in the diffraction pattern formed by a star on the focal plane of the objective.
[tex]\frac{\pi}{\lambda}Dsin\theta=\gamma[/tex]
Where \gamma is either the maxima (bright fringes) or minima (dark fringes) of the bessel function which occurs in the solution to the diffraction through a circular aperture.
[tex]r=f \theta[/tex]
Where f is the focal length.
Maxima of Gamma function: 5.136,8.417,...
This is not an attempt, this is part of the actual solution. I do not understand a certain aspect of it though.
So using the first equation above and solved for sine. I came into a problem though. The problem doesn't give the wavelength! The solution just says..
"Thus for wavelength of 550nm..."
And then they plug it in. Where did this come from?!
Thanks :D
550nm is green light - right in the middle of the visible spectrum and thus in the middle of the fringes/rings.
This sort of thing is common - IRL you are unlikely to have all the information you need to do a calculation right then and there. It may be difficult to get a figure too. So you have to make a reasonable guess. If you knew the spectra of the star in question, you would pick a different wavelength perhaps but you are only told that it is visible.
Thank you very much! That makes perfect sense :]
No worries then - have fun :)
As a scientist, it is important to always pay attention to the given information and make sure all necessary variables are included in your calculations. In this case, the wavelength of 550nm is likely given in the problem statement or it may be a standard value commonly used in optics calculations. If it is not explicitly given, it is important to clarify with the source of the problem or make an assumption based on common values. It is also important to double check your calculations and make sure they are consistent with the given information.
FAQ: Confused about this Optics problems Solution
What is optics?
Optics is the branch of physics that deals with the study of light and its behavior. This includes the properties of light, its interactions with matter, and how we can use it to understand and manipulate the world around us.
What are some common applications of optics?
Optics has many practical applications in our daily lives, including in the fields of medicine, telecommunications, and photography. It is also used in the development of technologies such as lasers, fiber optics, and microscopes.
What is the difference between geometric optics and physical optics?
Geometric optics is a simplified model that describes the behavior of light as rays that travel in straight lines and interact with objects according to the laws of reflection and refraction. Physical optics, on the other hand, takes into account the wave nature of light and describes its behavior in terms of diffraction, interference, and polarization.
Can you explain the concept of refraction?
Refraction is the bending of light as it passes through a medium with a different optical density. This can cause a change in the direction and speed of light. The amount of refraction depends on the angle of incidence and the refractive index of the medium.
How do lenses work?
Lenses are curved transparent objects that are used to refract light in a controlled manner. Convex lenses converge light rays towards a focal point, while concave lenses diverge light rays. They are commonly used in eyeglasses, cameras, and telescopes.
