Constructing Associated Sheaf of Abelian Groups
  • Thread starter disregardthat
In summary, we construct a sheaf G and a morphism f from F to G such that h = gf and G is unique up to isomorphism.
disregardthat
34
Given a presheaf F of abelian groups, we want to construct an associated sheaf G and a morphism f from F to G such that given a morphism h from F to a sheaf H, there is a unique morphism g from G to H such that h = gf. Furthermore, G will be unique up to isomorphism.
We construct it by letting the abelian group for an open subset U be G(U) = the set of functions [tex]s : U \to \bigcup_{P \in U} F_P[/tex], where [tex]F_P[/tex] denotes the stalk of F at P satisfying the following criterion:
1) [tex]s(P) \in F_P[/tex] for all P in U, and
2) For any P in U, there is a neighbourhood V of P in U such that for any Q in V, there is a t in F(V) such that the stalk of t in [tex]F_Q[/tex] is equal to s(Q).
I have proved that G is a sheaf, and I think we can define f by defining f(U) : F(U) --> G(U) by letting f(U)(s) be the constant function of (s,U), a germ in [tex]F_P[/tex] for all P.
Now, given an h from F to H, how can I define g : G --> H? The book says it's natural, but I just don't see it.
I would also appreciate some hints as to how to prove uniqueness of g after knowing how it is defined. I have proven uniqueness of G given uniqueness of g.
How can we show that [tex]F_P = G_P[/tex] for all P?
Really appreciate any help or comments!
don't you mean the disjoint union here? Or did you construct the stalks such that they are disjoint?
Try this: the morphism f determines a morphisms on the stalks. Thus for P, we have a morphism [tex]f_P:F_P\rightarrow H_P:s\rightarrow (f(s))_P[/tex]. Taking all these morphisms will get you a morphism [tex]\bigcup_{P}{F_P}\rightarrow \bigcup_{P}{H_P}[/tex]. Composing with this morphism will get you the desired morphism of sheaves. So the only thing you still need to do is show that [tex]\bigcup_{P}{H_P}[/tex] is a sheaf isomorphic to H.
The stalks of g determine g completely. So you must prove that g is unique in the stalks of the sheaf.
I suggest you show this first. You'll need to show that F_P is the direct limit of the G(U)'s. Have you put a topology on [tex]\bigcup_{P}{H_P}[/tex] yet. You'll have to use that the map [tex]p:\bigcup_{P}{H_P}\rightarrow X[/tex] (with [tex]p^{-1}(P)=H_P[/tex]) is a local homeomorphism...
May I ask you from what book you're learning sheaves. It's pretty hard to explain without knowing which notations you're familiar to...
Thank you for your reply micromass, but I have figured my questions out now. I misinterpreted the definition of the functions s, the sections of G. I thought initially that for each Q in V there is a t depending on Q in F(V) such that s(Q) = the stalk of t. It was the other way around, t is not depending on Q but only on V. It all went much more smoothly after I realized that.
By [tex]\bigcup F_P[/tex] I meant union, the author (Robin Hartshorne on Algebraic Geometry) presumably means the set of germs (V,s) which are equal if they are equal on some common open subset by the restriction morphisms. The classes agree on intersections of stalks, so we can assume they are all part of the set of all germs. Or we can just consider them all subsets of the direct limit of the abelian groups corresponding to every open subset.
EDIT: A topology on [tex]\bigcup H_P[/tex] never came in question, note that the union is only over P in the open subset U, not all of X. That F_P = G_P was actually quite easy, one can just choose a sufficiently small open subset of P in the domain of the stalks of functions in G on which they are constant, and we immediately have a 1-1 correspondence induced by the map from F to G.
EDIT again: I think there have been a slight miscommunication. The functions [tex]s : U \to \bigcup_{P \in U} F_P[/tex] satisfying 1) and 2) are supposed to make up the abelian group G(U).
FAQ: Constructing Associated Sheaf of Abelian Groups
What is an associated sheaf of abelian groups?
An associated sheaf of abelian groups is a mathematical construction that associates a group to each point on a topological space. This construction is used to study the topological space by looking at its local properties.
How is an associated sheaf of abelian groups constructed?
To construct an associated sheaf of abelian groups, we start with a topological space and a presheaf of abelian groups. Then, we define the sheaf of sections over open sets of the topological space. This sheaf is then called the associated sheaf of abelian groups.
What is the purpose of constructing an associated sheaf of abelian groups?
The purpose of constructing an associated sheaf of abelian groups is to study the local properties of a topological space. This construction allows us to understand the behavior of the topological space at each point, and then use this information to study the global properties of the space.
What are the applications of associated sheaf of abelian groups in mathematics?
The associated sheaf of abelian groups has many applications in mathematics, particularly in algebraic geometry, algebraic topology, and differential geometry. It is also used in other areas of mathematics such as number theory and representation theory.
Are there any real-world applications of associated sheaf of abelian groups?
Yes, there are real-world applications of the associated sheaf of abelian groups in areas such as physics, engineering, and computer science. It can be used to model and analyze various systems in these fields, including electromagnetic fields, networks, and data structures.
