Converge conditionally or converge absolutely
  • MHB
  • Thread starter shamieh
In summary, the given series $\sum^{\infty}_{n=1} \frac{(-1)^n}{n^2}$ is absolutely convergent since it is the same as the series $\sum^{\infty}_{n=1} \frac{1}{n^2}$ which is known to converge. Therefore, the series is not conditionally convergent or divergent. Additionally, the series can also be proven to converge using the Alternating Series Test (AST) or the p-series test. However, the question specifically asks for the type of convergence, so absolute convergence must be tested first.
shamieh
539
I'm confused. I know that \(\displaystyle \sum^{\infty}_{n = 1} \frac{1}{n^2}\) converges to \(\displaystyle \frac{\pi^2}{6}\) but I don't know what it does when it is alternating...
I'm given this \(\displaystyle \sum^{\infty}_{n= 1} \frac{(-1)^n}{n^2} \) and told to find out if it conditionally converges, diverges or converges absolutely.Can I use lopitals to get 1/n and then use the AST and say 0 <= 1/n+1 <= 1/n and lim n-> infinity = 0 therefore by AST the series converges?
Since you already know that $\displaystyle \begin{align*} \sum \left| \frac{ (-1)^n }{n^2} \right| = \sum \frac{1}{n^2} \end{align*}$ is convergent, the series is obviously absolutely convergent...
Wow I'm making these way harder than they need to be. I need to get better at inspection. But couldn't you also use the AST test since you really just have a \(\displaystyle \frac{1}{n^2}\) which is a number over infinity, which = 0 ? Also couldn't you just look at \(\displaystyle 1/n^2\) using the p series test as well to see that \(\displaystyle p > 1\) so converges?
Yes LAST can be used to determine the convergence of this series as well.
HOWEVER, your question is asking you to determine if the series is ABSOLUTELY convergent or CONDITIONALLY convergent. That means you need to test for absolute convergence first. You would go for LAST if you couldn't show the series is absolutely convergent.
FAQ: Converge conditionally or converge absolutely
What does it mean for a series to converge conditionally?
Convergence conditionally refers to a series in which the terms alternate in sign and do not approach a specific value, but the series still has a finite sum. In other words, the series may not converge to a particular number, but it does not diverge to infinity either.
Can a series converge conditionally and absolutely at the same time?
No, a series can only either converge conditionally or absolutely. If a series converges absolutely, it means that the series converges to a specific value and the terms do not alternate in sign. If a series converges conditionally, it means that the terms do alternate in sign and the series does not approach a specific value.
How can you determine if a series converges conditionally or absolutely?
To determine if a series converges conditionally or absolutely, you can use the ratio test or the root test. If the resulting limit is less than 1, the series converges absolutely. If the resulting limit is equal to 1, the test is inconclusive and further tests may be needed. If the resulting limit is greater than 1, the series diverges.
Is convergence conditional or absolute important in series analysis?
Yes, convergence conditionally or absolutely is important in series analysis because it helps determine the behavior of a series and whether or not it has a finite sum. This information is crucial in many applications, such as in physics and engineering, where series are used to model real-life phenomena.
Can a series that converges conditionally be rearranged to converge absolutely?
Yes, a series that converges conditionally can be rearranged to converge absolutely. This is known as the Riemann rearrangement theorem. However, not all series can be rearranged in this way, and it is important to consider convergence conditionally or absolutely when manipulating series.
