DCQE - Why don't we get idler pattern?
  • Thread starter San K
  • Tags
    dcqe
In summary: I hope this helps to clarify your doubts about the delayed choice quantum eraser experiment. In summary, the experiment shows the intricate relationship between the state of the signal photon and the path of the idler photon, and how it affects the observed interference pattern. This experiment challenges our understanding of the classical concepts of causality and locality, and it continues to be a topic of discussion and research in the field of quantum mechanics.
San K
911
In the delayed choice quantum eraser such as one described in the Kim paper...
http://en.wikipedia.org/wiki/Delayed_choice_quantum_eraserWe have five detectors D0, D1, D2, D3, D4 and D5
The signal photon strikes the detector D0.
Please note this discussion is more focussed on the idler and not the signal photon.
The idler strikes one of four remaining detectors (D1, D2, D3, D4, D5) each time it goes through the apparatus/experiment.
Can we get the interference pattern of the idler at each of the four detectors?
What would the pattern look like? (after removing "noise" via pairing of each idler with signal via the co incidence counter)
Why not? I might have missed some part of the experiment, that I don't understand.
Hello,
Thank you for your question. I am happy to provide some insight on the delayed choice quantum eraser experiment and the questions you have raised.
In the delayed choice quantum eraser experiment, the goal is to observe the interference pattern of the idler photon at each of the four detectors (D1, D2, D3, D4, D5) after it has passed through the apparatus. However, this is not always possible due to the nature of quantum mechanics and the concept of wave-particle duality.
First, let's understand the setup of the experiment. The signal photon is sent through a double-slit apparatus, which creates an interference pattern on the screen behind it. The idler photon is also sent through the same apparatus, but its path is split into two by a beam splitter. One path leads to the detectors D1-D4, while the other path leads to detector D5. The detectors are set up in a way that they can either detect the presence of the photon or not, but they cannot distinguish between which path the photon took.
Now, when the signal photon strikes detector D0, it is entangled with the idler photon. This means that the state of the signal photon is linked to the state of the idler photon. If we were to measure the state of the signal photon, we could determine which path the idler photon took, and therefore, we would not observe an interference pattern at the detectors D1-D4.
However, in the delayed choice quantum eraser experiment, the state of the signal photon is not measured until after the idler photon has passed through the apparatus and reached one of the detectors. This means that the path of the idler photon is not determined until after it has passed through the apparatus.
Now, to answer your question, can we get the interference pattern of the idler at each of the four detectors? The answer is yes, but it depends on the setup of the experiment. If we do not measure the state of the signal photon, then we can observe an interference pattern at the detectors D1-D4. However, if we do measure the state of the signal photon, then we will not observe an interference pattern at the detectors D1-D4.
What would the pattern look like? The interference pattern would be similar to the pattern observed at the double-slit apparatus when only the signal photon was sent through. It would be a series of light and dark
FAQ: DCQE - Why don't we get idler pattern?
1. Why is the idler pattern not observed in DCQE?
The idler pattern is not observed in DCQE because the process involves the conversion of photons from one wavelength to another, resulting in a distribution of wavelengths rather than a specific pattern.
2. Is there a specific condition or setup needed to produce the idler pattern in DCQE?
No, the idler pattern is a result of the specific properties of the materials used in the DCQE process, and does not require any specific conditions or setup.
3. Can the absence of the idler pattern in DCQE be explained by quantum mechanics?
Yes, the absence of the idler pattern in DCQE can be explained by quantum mechanics, specifically the uncertainty principle which states that it is impossible to know both the position and momentum of a particle at the same time. In DCQE, the conversion process results in a spread of wavelengths, making it impossible to produce a specific pattern.
4. Are there any practical applications for the idler pattern in DCQE?
While the idler pattern itself is not observed in DCQE, the process of converting photons from one wavelength to another has many practical applications, such as in telecommunications and quantum computing.
5. Is research still being done to understand the absence of the idler pattern in DCQE?
Yes, research is ongoing to further understand the mechanisms behind the absence of the idler pattern in DCQE and to explore potential applications of this phenomenon.
