Deceleration and Change of Direction
In summary, the question is asking for the acceleration of a baseball that was struck by a bat, given its initial and final velocities and the duration of impact. The answer can be determined by defining the positive direction and using vector notation. Ultimately, the baseball's acceleration is 5000 m/s^2 in the direction of the positive vector.
joel amos
104
A question from my textbook states:
A baseball moving at 20 m/s is struck by a bat and moves in the opposite direction at 30 m/s. if the impact lasted for 0.010 s, what was the baseball's acceleration?
Would the answer be -5,000 m/s^2?
Yep, that works. However, since the coordinate system wasn't defined for you, why not define the positive direction to be the direction of the acceleration? If you define the initial velocity to be -20 m/s and final velocity to be 30 m/s, the acceleration is a positive 5000 m/s2.
it's a good idea not to use the word "deceleration" when you are working out these things. Use the idea of vectors - which have signs.
If you draw a big arrow on your (imaginary, perhaps) diagram to define the direction you will use for Positive, stick to it, and, if the acceleration comes out as negative then this means the velocity in that direction is decreasing. If you want to talk to 'Joe Public', at that point, you can then use the word "deceleration'.
Thanks guys
The answer to this question would not be -5,000 m/s^2. To calculate the acceleration, we need to use the formula a = (vf - vi)/t, where vf is the final velocity, vi is the initial velocity, and t is the time of impact. In this case, vf = -30 m/s, vi = 20 m/s, and t = 0.010 s. Plugging these values into the formula, we get a = (-30 m/s - 20 m/s)/0.010 s = -5000 m/s^2. So, the baseball's acceleration is -5000 m/s^2, which indicates that it experienced a significant deceleration and change of direction during the impact with the bat.
FAQ: Deceleration and Change of Direction
What is deceleration?
Deceleration is the rate at which an object decreases its velocity. In other words, it is the change in velocity per unit of time.
How is deceleration measured?
Deceleration can be measured in meters per second squared (m/s^2) or in gravitational units (g). It is typically measured using a device such as a speedometer or an accelerometer.
What causes deceleration?
Deceleration is caused by forces acting in the opposite direction to an object's motion, such as friction or air resistance. It can also be caused by an object changing direction, resulting in a change in velocity.
How is deceleration related to change of direction?
Deceleration is often involved in change of direction. When an object changes direction, it must accelerate or decelerate in order to do so. This change in velocity is what causes the change in direction.
How does deceleration affect an object's motion?
Deceleration can cause an object to slow down or come to a stop, depending on the magnitude and direction of the deceleration. It can also affect an object's trajectory, causing it to change direction or curve. In some cases, deceleration can also cause an object to accelerate in the opposite direction.
