Deflection angle of a particle approaching a planet
In summary, we can calculate the eccentricity of a test particle approaching a planet of mass M and radius R by using the expression e = 1 + \frac{2v_{\infty}^2}{v_0^2}, where v_0 is the escape velocity at the pericentre distance r_0. The overall deflection of the test particle's orbit can be found using the expression \psi = \cos^{-1}(\frac{a(1-e^2)}{r_0} - 1), where a is the semi-major axis and r_0 is the distance from the center of the planet. For a spacecraft skimming Jupiter with v_{\infty} = 10 km
Deadstar
104
A test particle approaches a planet of mass M and radius R from in nity with speed
[tex]v_{\infty}[/tex] and an impact parameter p.
Show that the eccentricity may be written
[tex]e = 1 + \frac{2v_{\infty}^2}{v_0^2}[/tex]
where [tex]v_0[/tex] is the escape velocity at the pericentre distance [tex]r_0[/tex].
Use the expression for the true anomaly corresponding to the asymptote of the hyperbola ([tex]r \to \infty[/tex]) to show that the overall deflection of the test particle's orbit after it leaves the vicinity of the planet [tex]\psi[/tex], is given by [tex]\sin(\psi/2) = e^{-1}[/tex]: Given that [tex]r_0[/tex] must be greater than [tex]R[/tex] to avoid a physical collision, calculate the maximum deflection angles for
(i) a spacecraft skimming Jupiter, with [tex]v_{\infty} = 10 km s^{-1}[/tex],
[tex]\frac{1}{2}v_{\infty}^2 - \frac{GM}{r} = - \frac{GM}{2a}[/tex] where a is semi-major axis
[tex]r_0 = a(1-e)[/tex]
[tex]v_0^2 = \frac{2GM}{r}[/tex]
[tex]r = \frac{a(1-e^2)}{1 + e \cos(f)}[/tex]
[tex]\psi = f - (\pi - f)[/tex]
where f can be found on this diagram... http://img521.imageshack.us/img521/8254/123cg.jpg
Ok so I have done everything in this question except I don't think my answer is quite right. Seems to... extreme. Perhaps I have messed up the units or something (mathematician so not too used to the whole units thing...)
So for Jupiter we have
[tex]R = 71492000m[/tex]
[tex]M = 1.8986*10^{27}kg[/tex]
and gravitational constant...
[tex]G = 6.67300*10^{-11}[/tex]
Although really we just need the escape velocity which is 59.5 km/s
So this results in e = 1.056493186
Solving for [tex]\psi[/tex] we get [tex]\psi = 142.36[/tex] degrees which just doesn't seem quite right...
So, this should just be a case of plug in numbers but is 142.36 correct?
Thank you for your post. It seems like you have made some good progress on this problem. However, your answer for the maximum deflection angle does seem a bit high. Let's go through the problem step by step and see if we can find where the discrepancy lies.
First, let's write out the equation for eccentricity:
We can substitute in the expression for v_0:
e = 1 + \frac{2v_{\infty}^2}{\frac{2GM}{r}}
Simplifying, we get:
e = 1 + \frac{v_{\infty}^2r}{GM}
Now, we can use the expression for the true anomaly:
where f can be found on the diagram provided. We can also use the expression for r in terms of a and e:
Combining these equations, we get:
Now, let's substitute in the values for Jupiter:
a = 71492000m
e = 1.056493186
r_0 = 71492000m + R (we add R because the spacecraft is skimming Jupiter, not crashing into it)
Plugging these values in, we get:
\psi = \cos^{-1}(\frac{71492000m(1-1.056493186^2)}{71492000m + 71492000m} - 1)
\psi = \cos^{-1}(-0.056493186)
Using a calculator, we get:
\psi = 90.53 degrees
This is a much more reasonable answer for the maximum deflection angle. I'm not sure where your calculation went wrong, but I hope this helps you find the correct answer. Keep up the good work!
FAQ: Deflection angle of a particle approaching a planet
What is the deflection angle of a particle approaching a planet?
The deflection angle of a particle approaching a planet refers to the angle at which the particle's trajectory is bent due to the gravitational pull of the planet.
How is the deflection angle of a particle calculated?
The deflection angle of a particle can be calculated using the formula θ = 2GM/Rv^2, where G is the gravitational constant, M is the mass of the planet, R is the distance between the particle and the center of the planet, and v is the velocity of the particle.
What factors affect the deflection angle of a particle approaching a planet?
The deflection angle of a particle approaching a planet is affected by the mass of the planet, the velocity of the particle, and the distance between the particle and the center of the planet.
Why does the deflection angle of a particle change as it approaches a planet?
The deflection angle of a particle changes as it approaches a planet due to the increasing gravitational force exerted by the planet, which bends the particle's trajectory.
How is the deflection angle of a particle related to the concept of escape velocity?
The deflection angle of a particle is related to the concept of escape velocity because if the particle's velocity is greater than the escape velocity of the planet, the particle will not be deflected and will instead escape the planet's gravitational pull.
