Determine if integral domain or field
In summary: As established earlier, nothing non-zero multiplied by a real number yields zero. Thus, that system is not possible. The inverse is [a - b*sqrt(2)] / [a2 - 2*b2], which is not defined over the rationals. In summary, the conversation discusses the definitions of Integral Domain and Field, and how to determine if a given system is a Field. The conversation also touches on the concept of rationalizing denominators and its application in solving linear systems of equations.
Shackleford
1,656
I found the unity to be 1. I'm not sure how to determine 3) for each.
Integral Domain:
1) D has to be commutative ring (under multiplication)
2) D has to have a unity not equal to zero (also under multiplication)
3) D has to have no zero divisors (ab = 0)
Field:
1) F has to be commutative ring (under multiplication)
2) F has to have a unity not equal to zero (also under multiplication)
3) Each nonzero element in F has to have a multiplicative inverse
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110805_224110.jpg?t=1312602377
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110805_224012.jpg?t=1312602392
The real numbers have no zero divisors, so it's a pretty safe bet that both are at least integral domains. To determine if there is an inverse, don't start from scratch. Multiply (a+sqrt(2)*b)*(a-sqrt(2)*b) and try to figure out where to go from there.
Ah! Duh. I was focusing too much on the rationals a,b and forgetting that the term represents a real number.
So, there's no way to determine if there's an inverse if you start from scratch?
Why did you choose this? Just a good guess?
Yes, good guess. It gets rid of the sqrt(2). Which you have to do if you are finally going to get just 1. Now go from there.
(a+sqrt(2)*b)*(a-sqrt(2)*b) = 1
a2 - 2b2 = 1
a2 = 1 + 2b2
If b = 1, then a2 = 3
Then, a = sqrt(3), which is not a rational number. This is not a Field.
a2 - 2b2 = 1
a2 = 1 + 2b2
If b = 1, then a2 = sqrt(3).
Then, a is not a rational number. This is not a Field.
Ok, my guess was really just a hint. a^2-2*b^2 is unlikely to be 1. Now think about (a+b*sqrt(2))*k*(a-b*sqrt(2))=1 where k is some constant in your system. Can you solve for k if you are working in the rationals?
Is my counterexample correct? Did I show it's not a Field?
k = [a2 - 2b2]-1
k = [a2 - 2b2]-1
Well, no. Using that value of k, I'd say the inverse of a+sqrt(2) is (a-sqrt(2))/(a^2-2), isn't it? Your main worry over the rationals is whether a^2-2*b^2 could be zero.
Okay, you're right. There is a valid inverse if b = 1.
a2 - 2b2 = 0
a = sqrt(2)b
[itex]\frac{1}{a+ b\sqrt{2}}[/itex]
Rationalise the denominator.
You can't?
Shackleford said:
You can't?
I'm sure he can !
But the point is that you do it.
SammyS said:
I'm sure he can !
No. I'm saying you can't rationalize the denominator because there will always be root two down there. Is that right?
I thought we were getting towards being able to agree that the inverse of (a+b*sqrt(2)) is (a-b*sqrt(2))/(a^2-2*b^2)? In so far as that is defined. Is it defined over the rationals? Let's not go backwards here.
Oh, sorry. I guess that's next logical conclusion.
Is the inverse defined over the rationals? Not if sqrt(2) is in there.
You are still missing the whole point! [itex](a+ b)(a- b)= a^2- b^2[/itex]. I'm sure you learned that long ago. So what do you get if you multiply both numerator and denominator of
[tex]\frac{1}{a+ b\sqrt{2}}[/tex]
by
[tex]a- b\sqrt{2}[/tex]
I don't see why people in this thread have an aversion to "starting from scratch". Linear algebra is a very useful technique in abstract algebra, and both of the questions
  • What, when multiplied by (a + b[itex]\sqrt{2}[/itex]), gives 1?
  • What, when multiplied by (a + b[itex]\sqrt{2}[/itex]), gives 0?
are linear systems of equations in two unknowns. (treating a and b as "knowns")
Rationalizing denominators is a good trick, but far from required for this problem.
What do you mean 'if sqrt(2) is in there'? Do you mean sqrt(2) is in the rationals? Can you elaborate a bit?
Rationalizing is when you get rid of the square root in the denominator? I was wrong. You can rationalize the denominator with the difference of two squares trick.
[1/sqrt(2)] = sqrt(2)/2
As established earlier, nothing non-zero multiplied by a real number yields zero. Thus, that system is not possible. The inverse is [a - b*sqrt(2)] / [a2 - 2b2].
How can you be certain that [itex]a- 2b^2[/itex] is not 0 for some a and b?
I corrected the typo. It should be a2.Then a = sqrt(2)*b.
Related to Determine if integral domain or field
What is an integral domain?
An integral domain is a mathematical structure that is similar to a field, but does not necessarily have all of the properties of a field. It is a commutative ring with unity in which every nonzero element has a multiplicative inverse.
What is a field?
A field is a mathematical structure that consists of a set of elements, along with two operations (addition and multiplication), that satisfy a specific set of axioms. In a field, every nonzero element has a multiplicative inverse and the operations of addition and multiplication are both commutative and associative.
What is the difference between an integral domain and a field?
The main difference between an integral domain and a field is that a field has all of the properties of an integral domain, but an integral domain may not have all of the properties of a field. This means that while every field is an integral domain, not every integral domain is a field.
How can you determine if a mathematical structure is an integral domain?
To determine if a mathematical structure is an integral domain, you can check if it satisfies all of the properties of an integral domain. These properties include being a commutative ring with unity, having no zero divisors, and having a cancellation law for multiplication.
How do you determine if a mathematical structure is a field?
To determine if a mathematical structure is a field, you can check if it satisfies all of the properties of a field. These properties include being a commutative ring with unity, having no zero divisors, and having a multiplicative inverse for every nonzero element.
