Determine the Gravitational potential energy
Jv= √(2K.E./m) = √(2(5.22kJ)/(65kg)) = 3.05m/sIn summary, to determine the gravitational potential energy at the top of the slope compared to the bottom, use the formula P.E. = mgh. To find the kinetic energy at the bottom, subtract the energy lost to friction from the potential energy. To find the skier's speed at the bottom, use the formula v= √(2K.E./m).
Nicholasw
Question
A Skier with a mass of 65.0 kg. Including equipment, starts from rest and accelerates down a slope. The slope is 27.0 m higher at the top than the bottom. The work done on the skier by the kinetic friction is 1.20 x 10^4 J.
How would I determine the Gravitational potential energy at the top slope relative too the bottom?
Kinetic energy at the bottom?
And the skiers speed at the bottom of the slope?
The potential energy would just be mgh, with h = 27m.
Then to find the kinetic energy at the bottom you would subtract the energy lost to friction from the potential energy.
Once you have the kinetic energy, use (1/2)mv^2 = k, then solve for v to find the velocity.
P.E. = mgh (65kg)(9.81)(27m) = 17.22 kJ
(P.E.)17.22kJ - (fs)12.0kJ = 1/2mv^2
5.22kJ = 1/2mv^2 (K.E. bottom)
FAQ: Determine the Gravitational potential energy
What is gravitational potential energy?
Gravitational potential energy is the energy that an object possesses due to its position in a gravitational field. It is the potential for an object to gain kinetic energy as it falls towards the center of the gravitational field.
How is gravitational potential energy calculated?
The gravitational potential energy of an object can be calculated by multiplying the mass of the object by the acceleration due to gravity (9.8 m/s^2) and the height of the object above the ground.
What factors affect gravitational potential energy?
The two main factors that affect gravitational potential energy are the mass of the object and its height relative to the ground. The greater the mass and height, the greater the potential energy.
What is the unit of measurement for gravitational potential energy?
The unit of measurement for gravitational potential energy is Joules (J). This is the same unit used for all types of energy.
Why is gravitational potential energy important?
Gravitational potential energy is important because it is a fundamental concept in understanding the behavior of objects in a gravitational field. It is also an important factor in many real-life situations, such as in the design of roller coasters and the functioning of hydroelectric power plants.
