menco
- 43
You are tasked to reduce the vibrations of of an old air conditioning unit through the structure of a building. To do this you intend to mount the fan unit on 4 free-standing spring isolators with a non skid base. By choosing the appropriate springs and configuration you will be able to reduce the natural frequency of the system by a factor of 5 which will reduce the vibrations by 96%. The combined mass of the fan unit and spring system is 570kg and the fan operates at a frequency of 1750 rpm, determine the stiffness of the springs being installed.
w = 2(pi)f
w = sqrt(k/m)
So I start by converting rpm to hz which gives me 29.2 hz for f.
I divide the mass of the system by 4 due to it having 4 springs which will give me 142.5kg
Next I find the angular frequency
w = 2(pi)(29.2)
= 183.469 rad/s (then divide this by a factor of 5? to reduce the vibrations)
= 36.6938 rad/s
then put all of this into the final formula to find k
w = sqrt(k/142.5)
k = 142.5(36.6938)^2
= 195502 Nm (1.955x10^5 Nm)
