Determine the tension in each section of rope
In summary, the conversation discusses the determination of the minimum force needed to lift a piano using a pulley apparatus and the tension in each section of rope. The correct values for the tensions in FT1, FT2, and FT4 are Mg, while the tension in FT3 is still being determined. The tension in FT3 can be approximated by assuming all tension forces on the upper pulley act vertically and using Newton's First Law to solve for the value.
helppleaseee
picture of problem:
http://img.photobucket.com/albums/v223/lilaznbabe/4_56.gif
(a) What minimum force F is needed to lift the piano (mass M) using the pulley apparatus shown in Fig. 4-56? (Enter your answers in terms of some multiple of Mg.)
____ Mg (I got .5)
(b) Determine the tension in each section of rope: FT1, FT2, FT3, and FT4.
Tension in FT1?
____ Mg (I got .5)
Tension in FT2?
____ Mg (I got .5)
Tension in FT3?
____ Mg
Tension in FT4?
____ Mg (I got 1)
ok so i only need help on FT3...
thanks!
helppleaseee said:
1.
picture of problem:
____ Mg (I got .5)
Tension in FT1?
____ Mg (I got .5)
Tension in FT2?
____ Mg (I got .5)
Tension in FT3?
____ Mg
Tension in FT4?
____ Mg (I got 1)
thanks!
the best you can do is approximate it by assuming all tension forces on the upper pulley act vertically. You've got the others correct, so why not continue in the same manner to solve for FT3 in the same manner using Newton 1?
i initially thought it was 1...but that is wrong, then i thought .5 but something tells me that's not right. :frown:
what is causing the tension in #3?
draw a FBD of the pulley with all the forces on it
in order for this system to be in equilibrium the sum of the forces must be 0,
so the forces up must equal the forces down
yay! thanks soooo much i got it!
FAQ: Determine the tension in each section of rope
What is tension?
Tension is the force exerted by a rope or cable when it is pulled tight by opposing forces.
How is tension calculated?
Tension can be calculated by dividing the force applied to the rope by the cross-sectional area of the rope.
Why is it important to determine the tension in a rope?
Determining the tension in a rope is important in ensuring the safety and stability of structures that rely on the strength of the rope. It also helps in determining the maximum weight or load that the rope can support.
What factors can affect the tension in a rope?
The tension in a rope can be affected by factors such as the force applied, the length and thickness of the rope, and the angle at which the rope is pulled. Friction and the weight of the rope itself can also impact the tension.
How can the tension in each section of rope be determined?
The tension in each section of rope can be determined by using equations that take into account the forces acting on the rope, its length, and the angle at which it is pulled. Advanced techniques such as strain gauges and load cells can also be used to measure tension in specific sections of rope.
