Determine Work done on the puck?
In summary, the puck does not stop when the string is pulled, but the force applied by the string reduces the radius of the puck. The change in kinetic energy is then found by multiplying the initial kinetic energy by the change in radius.
jumpingjack90
Determine Work done on the puck??
The puck in the figure has a mass of 0.799 kg. Its original distance from the center of rotation is 76.2 cm, and the puck is moving with a speed of 91.0 cm/s. The string is pulled downward 38.2 cm through the hole in the frictionless table. Determine the work done on the puck.
W=fd
centripetal force=mv^2/r
KE=1/2 mv^2
Not really sure how to do this problem. I tried using the formula mv^2/r and (0.799)(0.910)^2/(0.762) = 0.868 Joules, but this is not the right answer.
r is not 0.762 - it changes.
That's assuming I have correctly guessed what was on the image...
ok. I understand that the radius changes, but How exactly do you solve this problem with the equations given?
Initial KE - Final KE is what you are looking for. The only factor contributing to the energy change is "pulling the string". There is no potential or friction in the problem so the total change in the energy equals Initial KE - Final KE which is the work done "by the puck" stick a negative sign in front of your result and that is the work done on the puck.
Initial KE= (1/2)(0.799)(0.910)^2= 0.33082595 J
Final KE= VF= 0 m/s so, (1/2)(0.799)(0)^2=0
0.33082595-0=-0.33082595 J which isn't the correct answer. What am I missing in the Final KE?
The puck does not stop, you just pull the string thus reducing the radius, The force you apply by pulling the string applies no torque so angular momentum is conserved too.
mr1v1 = mr2v2
You now what r2 is
Now you can find v2 in terms of v1.
So you can find the change in kinetic energy.
FAQ: Determine Work done on the puck?
What is work done on a puck?
Work done on a puck is the measure of the force applied to the puck over a certain distance. In scientific terms, it is the product of force and displacement in the direction of the force.
How is work done on a puck calculated?
The formula for calculating work done on a puck is W = F*d, where W is the work done in joules (J), F is the force in newtons (N), and d is the displacement in meters (m).
What types of forces contribute to the work done on a puck?
There are several types of forces that can contribute to the work done on a puck, including frictional forces, gravitational forces, and applied forces from an external source.
What is the unit of measurement for work done on a puck?
The unit of measurement for work done on a puck is joules (J). This is the same unit used to measure energy.
Can the work done on a puck be negative?
Yes, the work done on a puck can be negative if the force and displacement are in opposite directions. This indicates that the force is acting against the direction of motion, resulting in work being done in the opposite direction.
