Determining Intersections of Quadratic Equations with a Parameter
In summary, the conversation involved discussing two equations and their intersections for different values of k. After determining the correct det function and graphing the equations, the correct values for one, two, or no intersections were found for each value of k. It was suggested to use a computer package or website to check for computational mistakes when needed.
t_n_p
595
I think I've got everything down pat, I just need someone to check that I'm correct.
2 equations:
y= kx2+3x-6
y=x2-2x+3k
For what values of k do the 2 equations intersect:
a) no times
b) one time
c) 2 times
equate the equations:
kx2+3x-6 = x2-2x+3k
x2(k-1) + 5x + (3k-6) = 0
det = b2-4ac where a = (k-1), b = 5, c = (3k-6)
therefore det = -12k2 + 36k -1
a) for no intersection, det < 0
b) for one intersection, det = 0
c) for two intersections, det > 0
det = 0,
-12k2 + 36k -1 = 0
use quadratic equation again,
k = [-9 ± √(78)]/-6
therefore
a) no intersection when k < [-9 ± √(78)]/-6
b) one intersection when k = [-9 ± √(78)]/-6
c) two intersections when k > [-9 ± √(78)]/-6
sound good?
Your reasoning is right for the questions about intersections (one - det = 0, none det < 0, two det > 0), but you have to pay attention to what you are doing when you solve for k.
Firstly the det function is wrong. My working shows the following:
det = b^2 - 4ac
= 25 - 4*(k-1)(3k-6)
= 25 - 4*3*(k-1)(k-2)
= 25 - 12(k-1)(k-2)
= 25 - 12(k^2 - 3k + 2)
= 25 - 12k^2 + 36k - 24
= -12k^2 + 36k + 1
So I got a "+1" term instead of a "-1" term. I'll let you figure out the critical point (ie the roots of the equation)
The other thing I want to point out is that your idea for the inequality is wrong. The graph is essentially a quadratic that is concave down (ie the curve is bounded at the top and not the bottom).
The graph will be positive when its in between the roots and it will be negative when its outside this range and not the roots themselves. If this is confusing use a package to plot the quadratic and take note when the function is positive, zero, and negative.
Like I said you got the concepts for the first part right, but not the inequality. If you're ever in doubt draw a picture to clear up any misconceptions.
ok think I got you.
Figured out the +1 instead of -1 no problem.
So I figured out the graph, and the intercepts are -0.0175 & 3.0275
Therefore,
one solution when det = 0 (i.e. when k = -0.0175 or 3.0275)
2 solutions when det > 0 (i.e. positive y value, i.e. -0.0175 < k < 3.0275)
no solution when det < 0 (i.e. negative y value, i.e. k < -0.0175 or k > 3.0275)
sound better now?
t_n_p said:
ok think I got you.
Therefore,
sound better now?
Yes that looks correct well done.
actually spotted another mistake.
when equating the 2 equations, the constant term should be (-6-3k) not (3k-6)
Computational mistakes can be a common and an absolute pain in the arse. I don't know if you're allowed to, but if you suspect something is wrong, use a computer package or a website to check the answer with your paper and pen solution. I'm not saying don't do paper and pen solutions anymore, but a quick check can answer to you if you made a mistake or not.
FAQ: Determining Intersections of Quadratic Equations with a Parameter
What is a determinant?
A determinant is a mathematical value that can be calculated for a square matrix. It represents certain properties of the matrix, such as its volume or the solutions to a system of linear equations.
Why is finding the determinant important?
Finding the determinant is important because it can be used to solve systems of linear equations, determine if a matrix is invertible, and find the area or volume of a shape represented by the matrix.
How do you calculate the determinant of a matrix?
The determinant of a 2x2 matrix can be calculated by multiplying the two main diagonal elements and subtracting the product of the two off-diagonal elements. For higher dimensions, there are various methods such as the cofactor expansion method or the Gaussian elimination method.
Is there an easy way to find the determinant of a matrix?
There is no single easy method to find the determinant of a matrix, as it depends on the size and complexity of the matrix. However, with practice and understanding of the various methods, it can become easier to calculate the determinant.
What are some real-life applications of determinants?
Determinants have various real-life applications, such as in physics to calculate the moment of inertia of a physical object, in economics to solve optimization problems, and in computer graphics to rotate and scale images.
