Determining the density of a singularity
In summary, singularities are mathematically absurd and involve dividing by zero, which is undefined. It is also unclear how a real object can be defined using such mathematics. Most people do not expect singularities to exist physically and it is thought that GR breaks down in the presence of singularities. The idea of point particles with infinite densities is not necessarily problematic, but the conflict between quantum theory and classical GR at the Planck scale suggests that singularities may not be real physical objects.
Perpendicular
49
I have a question about singularities. Determining the density of a singularity involves the mathematically absurd and undefined function of dividing by zero.
What I don't get is this : How can a mathematically absurd entity exist in reality ?
Also, if you multiply the density of a singularity by its volume to get its mass, you get the mass of the singularity as 0. Is that not absurd ?
Ultimately, what I want to know is : How can a real object be defined in absurd and undefined mathematics? That seems to be a revokement of everything I've ever learnt.
First point: You can't multiply the density of a singularity by its volume and get 0 as its mass. The density is infinite, so this operation is not defined.
Second point: Most people don't expect singularities to exist physically, but rather as a sign that GR breaks down and that a quantum theory of gravity is needed to properly explain what is going on on those scales.
Either that or we just don't have the right math to work with it...but I think the more popular idea is that GR breaks down.
dividing by zero is not a mathematical absurdity, to be sloppy a/0 = infinity, however to be more presice its the limit as we approach zero
Dividing by zero is undefined. It was never defined as the limit as we approach zero. The limit is a limit, the division is a division.
Even for the limit, the 2-sided limit does not exist, and the 1-sided limit diverges which means that the limit does not exist within the real numbers.
You can have extensions of the real numbers like the Riemann sphere which include an infinite number which allows division of a nonzero number by zero to have a well-defined answer. In general there's nothing intrinsically wrong with having certain quantities go to infinity in a physical theory, for example the idea of point particles with finite mass in Newtonian gravity (or point particles with finite charge in classical electromagnetism) needn't lead to any breakdowns in your ability to predict later states from earlier ones in a deterministic manner despite the presence of infinite densities. The reason GR is thought to break down in the neighborhood of singularities is not just because infinities are bad, but because specific aspects of quantum theory seem to conflict with classical GR once you get to the Planck scale. If not for this type of conflict physicists would probably be happy to accept the idea that singularities might be real physical objects.
FAQ: Determining the density of a singularity
What is a singularity?
A singularity is a point in space where the laws of physics break down and the gravitational pull becomes infinite. It is typically associated with black holes.
How is the density of a singularity determined?
The density of a singularity is determined by calculating its mass and dividing it by its volume. This can be done using various equations and models, such as the Schwarzschild metric or the Kerr metric.
Can the density of a singularity be measured directly?
No, the density of a singularity cannot be measured directly as it is a theoretical concept rather than a physical object that can be observed.
Is the density of a singularity constant?
No, the density of a singularity can vary depending on its mass and volume. As a black hole grows in mass, its density will decrease.
Why is it important to determine the density of a singularity?
Determining the density of a singularity is important for understanding the properties of black holes and their effects on the surrounding space. It also plays a crucial role in theories of gravity and the structure of the universe.
