Determining wheter point lie on line
  • Thread starter salistoun
  • Tags
    Line Point
In summary, the conversation is about determining whether two given points lie on a given line with a parametric equation. The first point is (5,-6,10) and the second point is (3, 3, 8). By solving the vectorial equation, it is determined that these points do not match the parametric equation, therefore they do not lie on the line.
salistoun
Hi all,
How do I go about solving the following question?
Determine whether the points (5 , -6 , 10) and (3, 3 , 8) are on the line
x = 2 + t; y = 3 - 3t, z = 4 + 2t
Stephen
salistoun said:
Hi all,
Stephen
Just find out whether there exists a value [itex]\,t\in\Bbb R\,[/itex] s.t. [itex]\,(5,-6,10)=(2+t,3-3t,4+2t)\,[/itex] , and the same with the other vector...
DonAntonio
Hi Don,
If I'm correct, the parametric equation for the following points is:
x = -2t + 5, y = -9t - 6 and z = -2t + 10
So no values are matching this parametric
x = 2 + t; y = 3 - 3t, z = 4 + 2t.
So therefore it does not lie on the line right?
salistoun said:
Hi Don,
What is "the following point"? The point is given to you: (5,-6,10), period. You only have to solve the easy vectorial equation I wrote in my first post.
DonAntonio
Thanks Don i do get what u saying
FAQ: Determining wheter point lie on line
How do you determine if a point lies on a line?
To determine if a point (x,y) lies on a line, you can use the slope-intercept form of a line and plug in the x and y values of the point. If the resulting equation is true, then the point lies on the line.
What is the slope-intercept form of a line?
The slope-intercept form of a line is y = mx + b, where m is the slope of the line and b is the y-intercept (the point where the line crosses the y-axis).
Can a point lie on a vertical line?
No, a point cannot lie on a vertical line because a vertical line has an undefined slope. This means that for a given x-value, there is no single y-value that can be associated with it.
Are there other ways to determine if a point lies on a line?
Yes, there are other ways to determine if a point lies on a line, such as using the point-slope form or the standard form of a line. However, the slope-intercept form is the most commonly used method.
Can multiple points lie on the same line?
Yes, multiple points can lie on the same line. This is because a line extends infinitely in both directions, so there are infinitely many points that can lie on it.
13K
