Dielectric Modulation: Motion Sensor, 200V Containment Field, 100mV Modulation
In summary, the conversation was about a recently developed motion sensor that introduces charge into an electric field. They are trying to find a simple formula to describe how the sensor operates, specifically deriving a voltage modulation by modulating the capacitance while keeping the charge constant. Bob suggests using the formula V=Q/C, but Calvin clarifies that the capacitor is fixed and they use the charge on the edges of a plastic impeller wheel to modulate the dielectric field. They are considering the term "field displacement" to describe this operation.
Calvin Cox
We have recently developed a motion sensor that introduces charge into an electric field. From the 200V (containment field) we derive a modulation of 100mV. Although the sensor has passed pre-production tests we are struggling to come up with a simple formula to describe the operation. Can anyone help?. Regards - Calvin
I think you are referring to deriving a voltage modulation by modulating the capacitance C while holding charge Q constant:
V = Q/C
C = εε0A/x for parallel plate capacitor with area A, separation x, dielectric constant ε, and ε0 = 8.85 x 10-12 Farads per meter.
So V = Qx/(εε0A)
So dV/dt = Q[1/(εε0A)·dx/dt - x/(εε0A2)·dA/dt - x/(ε2ε0A)·dε/dt]
= [Q/C]·[1/x ·dx/dt -1/A ·dA/dt - 1/ε ·dε/dt]
Bob S
Thanks you for that, Bob.
It is not quite as you have assumed from my crude description: the capacitor is fixed and we utilise the charge congregated on the edges of the blades of a plastic impeller wheel to modulate the dielectric field. We were thinking perhaps of 'field displacement' ?
FAQ: Dielectric Modulation: Motion Sensor, 200V Containment Field, 100mV Modulation
What is dielectric modulation?
Dielectric modulation is a process by which the electrical properties of a material, such as its ability to store an electric charge, are manipulated in order to control the flow of electricity.
How does a motion sensor use dielectric modulation?
A motion sensor uses dielectric modulation to detect changes in the electric field caused by objects moving within its range. As the sensor's electric field is modulated, any changes in the field caused by movement are detected and used to trigger an alarm or other response.
What is the purpose of a 200V containment field?
A 200V containment field is used to create a stable and controlled environment for the dielectric modulation process. It helps to prevent interference from external electric fields and ensures that the modulation is consistent and accurate.
How does the 100mV modulation affect the sensor's sensitivity?
The 100mV modulation determines the sensitivity of the motion sensor. A higher voltage will result in a more sensitive sensor, as it can detect smaller changes in the electric field. However, the 100mV modulation must be carefully calibrated to avoid false alarms from external interference.
Can dielectric modulation be used for other applications besides motion sensing?
Yes, dielectric modulation has a wide range of applications beyond motion sensing. It is commonly used in electronic devices such as capacitors, transistors, and sensors, and is also being explored for use in energy storage and conversion technologies.
