GR191511
- 76
- 6
Are they equivalent to each other?Thank you.
Thanks...In《A First Course in General Relativity》page 151:Dale said:No, they are not. Locally flat refers to the spacetime and locally inertial refers to a reference frame or an object.
Locally flat just means that tidal forces go to 0 faster than first order. It is always true for every spacetime regardless of the curvature.
Locally inertial means that we are using local coordinates in which the metric is ##ds^2=-c^2 dt^2 + dx^2 + dy^2 + dz^2##. This is not always true for every coordinate system, even if the spacetime is flat.
The paragraph above seems to say that locally flat is equivalent to locally inertial.Dale said:What specifically don't you understand? The more detail you can provide the more likely we are to be able to help.
That's true, because in a pseudo-Riemannian manifold by definition is torsion-free, i.e., the uniquely defined pseudo-metric-compatible affine connection is given by the usual Christoffel symbols.GR191511 said:The paragraph above seems to say that locally flat is equivalent to locally inertial.
How does the author define those two terms? Different authors may use the same term differently. And how do they define "this coordinate system"?GR191511 said:The paragraph above seems to say that locally flat is equivalent to locally inertial.
Schutz.vanhees71 said:Good point. Which book are we talking about?
How about “locally inertial means that we are using local coordinates in which the coordinate acceleration of a test mass is equal to its proper acceleration”? That allows for non-Cartesian coordinates (polar, for example) while still excluding rotating and accelerating frames.Dale said:Locally inertial means that we are using local coordinates in which the metric is ##ds^2=-c^2 dt^2 + dx^2 + dy^2 + dz^2##. This is not always true for every coordinate system, even if the spacetime is flat.
I would add: "... at the instance of coordinate time, when the proper accelerated test mass is momentarily at rest with reference to the local coordinates".Nugatory said:How about “locally inertial means that we are using local coordinates in which the coordinate acceleration of a test mass is equal to its proper acceleration”?
... if the test mass does not move along the rotation axis, and including what I wrote above.Nugatory said:while still excluding rotating ... frames
No, it says that in a locally flat spacetime, it is always possible to find a locally inertial coordinate system at any point. That doesn't mean "locally flat" and "locally inertial" are the same.GR191511 said:The paragraph above seems to say that locally flat is equivalent to locally inertial.
I think that requirement is not necessary (non-zero velocity with zero coordinate and proper acceleration is generally consistent with inertial motion) except to close loopholes such asSagittarius A-Star said:I would add: "... at the instance of coordinate time, when the proper accelerated test mass is momentarily at rest with reference to the local coordinates".
and it's a very big hammer for that purpose. Surely there's a way of capturing the notion of "no fictitious forces needed" exactly?... if the test mass does not move along the rotation axis
In polar coordinates, doesn’t a tangentially moving inertial object have coordinate acceleration for both ##r## and ##\theta##Nugatory said:How about “locally inertial means that we are using local coordinates in which the coordinate acceleration of a test mass is equal to its proper acceleration”? That allows for non-Cartesian coordinates (polar, for example) while still excluding rotating and accelerating frames.
Isn't it is possible to define an accelerated reference frame, in which the coordinate-acceleration of a moving and accelerated particle is equal to the particle's proper acceleration?Nugatory said:I think that requirement is not necessary
I think so, yes. For example, consider motion in the y or z direction in a Rindler frame. However, if we add that the coordinate and proper accelerations must be equal in any direction, I don't think so.Sagittarius A-Star said:Isn't it is possible to define an accelerated reference frame, in which the coordinate-acceleration of a moving and accelerated particle is equal to the particle's proper acceleration?
Consider the ##x## direction of a Rindler frame and following scenarios:Ibix said:If we're allowed to pick our ##v^\mu##, as I did in my Rindler example above, then it is possible to find four velocities that have zero coordinate acceleration and zero proper acceleration even in non-inertial frames.
True, but in GR they are, because you assume that spacetime is a pseudo-Riemannian manifold (i.e., with no torsion and the affine connection thus the unique metric-compatible one given by the usual Christoffel symbols). Weinberg derives this from the assumption that there's always a local inertial frame in any point of spacetime.PeterDonis said:No, it says that in a locally flat spacetime, it is always possible to find a locally inertial coordinate system at any point. That doesn't mean "locally flat" and "locally inertial" are the same.
Casually, I would say equal and opposite. Rindler is well matched to an accelerating lift scenario, and a free faller would see the lift floor coming up with the same magnitude of acceleration an observer on the floor would see the free faller coming down with. The "midpoint" would be a downward accelerating observer seeing the floor accelerating upwards with the same coordinate acceleration magnitude as their own proper acceleration. I suspect that's only instantaneously correct, though - sooner or later the observers must pass through each other's Rindler horizons, and then their coordinate acceleration becomes undefined.Sagittarius A-Star said:Isn't there a scenario "in between", were both are equal?
You are right. I forgot the sign. Then consider in the Rindler frame a rocket, moving in ##x## direction (="upwards") with "almost ##c##" and a proper acceleration in the opposite direction (downwards). Time dilation reduces the ratio between coordinate acceleration and proper acceleration.Ibix said:Casually, I would say equal and opposite.
No. Because “flat” is a term that describes a spacetime and “inertial” is a term that describes a reference frame, worldline, or coordinate chart. You wouldn’t say “this is an inertial manifold” and you wouldn’t say “this is a flat reference frame”, so the terms are not interchangeable.vanhees71 said:True, but in GR they are, because you assume that spacetime is a pseudo-Riemannian manifold
Yes, that I agree withvanhees71 said:What I meant is that if you assume spacetime to be a (pseudo-)Riemannian manifold this implies that it's locally flat,
Where is the zero order?##\eta_{\mu \nu}##?vanhees71 said:$$g_{\mu \nu}(q) = \eta_{\mu \nu} + \frac{1}{2} \partial_{\rho} \partial_{\sigma} g_{\mu \nu}(q_0) (q^{\rho} -q_0^{\rho})(q^{\sigma}-q_0^{\sigma}) + \mathcal{O}(q-q_0)^3).$$
The second derivatives of ##r(t)## and ##\theta(t)## are non-zero but it’s the position vector ##\textbf{R}=r(t)\hat{r}## that we care about, and its second derivative ##\ddot{\textbf{R}}## will be zero.Dale said:In polar coordinates, doesn’t a tangentially moving inertial object have coordinate acceleration for both ##r## and ##\theta##
Ah, I see. You are using “frame” to mean something different from “coordinate chart”. Possibly you mean something like a tetrad? So you could describe an inertial tetrad in terms of a polar coordinate basis.Nugatory said:The second derivatives of ##r(t)## and ##\theta(t)## are non-zero but it’s the position vector ##\textbf{R}=r(t)\hat{r}## that we care about, and its second derivative ##\ddot{\textbf{R}}## will be zero.
(Belated reply because I just noticed that this saved draft has been rotting unposted for the past few days)
Do you mean that a tetrad/verbatin can be said inertial when its unit timelike vector field is indeed inertial (i.e. its timelike integral curve results in a geodesic of underlying spacetime) ?Dale said:Ah, I see. You are using “frame” to mean something different from “coordinate chart”. Possibly you mean something like a tetrad? So you could describe an inertial tetrad in terms of a polar coordinate basis.
I was using “frame” to mean “coordinate chart”
Yes, with the additional restriction that the spacelike vector fields do not rotate along the timelike integral curvescianfa72 said:Do you mean that a tetrad/verbatin can be said inertial when its unit timelike vector field is indeed inertial (i.e. its timelike integral curve results in a geodesic of underlying spacetime) ?
I agree and would add some further distinctions:Dale said:No. Because “flat” is a term that describes a spacetime and “inertial” is a term that describes a reference frame, worldline, or coordinate chart. You wouldn’t say “this is an inertial manifold” and you wouldn’t say “this is a flat reference frame”, so the terms are not interchangeable.
The main difference between locally flat and locally inertial is that locally flat refers to a region of spacetime where the curvature is negligible, while locally inertial refers to a reference frame in which the laws of physics are described by the principles of special relativity.
Locally flat and locally inertial are related in the sense that a region of spacetime must be locally flat in order for a reference frame to be locally inertial. In other words, a reference frame can only be considered locally inertial if it is in a region of spacetime where the curvature is negligible.
Yes, a region of spacetime can be both locally flat and locally inertial. In fact, this is the case in the absence of any gravitational fields. In such a region, the laws of physics can be described by the principles of special relativity and the curvature of spacetime is negligible.
Some examples of locally flat regions of spacetime include outer space far from any massive objects, the inside of a uniformly moving spaceship, and a small region around an object with a very small mass.
The concept of locally flat and locally inertial is an important aspect of the theory of general relativity. This theory states that the curvature of spacetime is directly related to the distribution of matter and energy in the universe. Locally flat regions of spacetime are used as a reference point to describe the effects of gravity in the theory of general relativity.
