Dimension of intersection of U and V
In summary, if W is a subspace of the vector space X, and every vector in the basis of X is also found on the basis of W, then W has dimension k.
simmonj7
66
Prove true:
For any subspaces U,V of R^n dim(U intersect V) <= min(dim(U), dim(V))
Min(a,b) = the minimum value of A and B
I know this statement is true however I can't quite figure out where to start on how to prove this...Help please.
The best way to approach this is to think about the subspace generated by intersection(U,V)... call it W for short. The dimension refers to the size of the basis, so any vector on W will also be found on U and found on V. If you think about V being the bigger one (say size m for dim|V| and size k for dim|U|), a vector w on W will have an expression as a linear combination in the basis of V and in the basis of U. So w can be written as a combination of of m vectors on V , and k vectors on U (k<m). Since they are subspace of the same vector space, they get their basis from the same vector space. Since W is also a subspace of the larger vector space, it gets its basis from that too.
Think of it in the sense that , in order for a vector to be on the basis of W, it has to be on the basis of V and U, since U has less vectors in its basis, there is going to be at least (m-k) vectors on the basis of V that will not be on the basis of W.
Ok you have quite a few typos in your statement so what you are trying to say at some points isn't quite clear.
(U intersect V) is contained in U and V. Try that.
Well I'd say use lagrange's formula from group theory, but I'm not sure how to delineate that.
OK say you have the original vector space X, where X has the basis {e1,e2,e3...en}
for a subspace V of X, the basis of V is a subcollection of the basis of X , ie V has a basis {e1,e5,e7,..e(n-1)} say for a grand total of M vectors in the basis.
now consider another subspace U of X, but this one has {e1,e3,e8,...en} , we'll say K vectors, where K<M.
Now consider the basis of the intersection of U and V =W.
If every vector in the basis of U is in W, then W has dimension k. V will have extra basis vectors that U will not have, so Dim(u,v) would be k. where k is the min (dim(U),dim(V))
but that's assuming that every vector on the basis of U is found on the basis of V.
So that means the dim(u,v) would be less than the min(dim(u),dim(v))
like say X has basis {e1,e2,e3,e4,e5,e6}Dim(X)=6 and U has {e1,e4,e5} (dim U=3) and V has {e1,e3,e4,e6} dim(v)=4
then the only vectors on the basis of W would be e1 and e3 , so it'd have dim(2)
Thank you for editing your statement.
I proved it using the properties of a p dimensional subspace which actually works a lot better and is simpler than what you are trying to say.
FAQ: Dimension of intersection of U and V
What is the definition of "Dimension of intersection of U and V"?
The dimension of intersection of U and V refers to the number of dimensions that are shared by both sets U and V. It represents the common characteristics or properties that exist in both sets.
How is the dimension of intersection of U and V calculated?
The dimension of intersection of U and V can be calculated by finding the number of elements that are present in both sets U and V. This can be done by taking the intersection of the two sets and counting the number of elements in the resulting set.
What is the significance of the dimension of intersection of U and V in science?
The dimension of intersection of U and V is important in science because it helps identify the similarities and differences between two sets. It can be used to analyze and compare data, and to understand the relationships between different variables or concepts.
How does the dimension of intersection of U and V relate to the concept of dimensionality?
The dimension of intersection of U and V is a measure of the number of dimensions that are shared by two sets. This is related to the concept of dimensionality, which refers to the number of independent variables or factors that are needed to describe a system or phenomenon.
Can the dimension of intersection of U and V be greater than the dimensions of the individual sets?
Yes, it is possible for the dimension of intersection of U and V to be greater than the dimensions of the individual sets. This occurs when the two sets share multiple dimensions, resulting in a higher overall dimension of intersection.
