Dimension of the stress energy tensor
In summary: In geometrized units, G and c are both set to 1. This means that all units of distance, time, and mass are equivalent, and thus the conversion between them is also 1. Therefore, if we measure time in cm, distances in cm, and masses in cm, the conversion between these units is still 1. This does not change the fact that the components of a tensor can have different units depending on the coordinates used. Regarding the second issue, the stress-energy tensor does not have the same units as the coefficient of T in the GR equation. The stress-energy tensor has units of distance^-2, as stated before, while the coefficient of T has units of distance^-1. This
PerpStudent
30
The coefficient of the stress energy tesor in the GR equation reduces to 8π/Ν, where N = {"(Kg)m/s^2.} Is it correct to conclude that all the elements of the stress energy tensor must have the dimension of N = (Kg)m/s^2 since the curvature and metric tensors on the other side of the equation are dimensionless?
No. This depends completely on the choice of metric. The metric tensor does not need to be dimensionless, it can even have different dimensions in different components depending on the coordinates (c.f., the metric in polar coordinates on R^2 is diag(1,r^2)).
Likes bcrowell
No, I don't think this is right.
First off, nobody actually does calculations in GR using SI units. The normal way you would work would be to use geometrized units, in which G=c=1, finish the calculation, and then at the end if you had a result where you needed to plug in numerical data, reinsert the factors of G and c.
The next thing to realize is that it's often natural to use coordinate systems where different coordinates have different units, e.g., spherical coordinates in which r and t have units of distance, but the the angles are unitless. When you write out a tensor in terms of its components, in this type of mixed-unit coordinate system, the different components of the tensor can all have different units. Therefore it doesn't always make sense to talk about what units a tensor has.
But suppose we're using a coordinate system such that all the coordinates have units of distance. Then the metric is unitless. The Christoffel symbols are derivatives of the metric, so they have units of distance^-1. The Riemann tensor can be expressed in terms of derivatives of the Christoffel symbols, so it has units of distance^-2. So does the Ricci tensor. Therefore in geometrized units, the stress-energy tensor also has units of distance^-2. This makes sense because the stress-energy tensor can be thought of in the Newtonian limit as a mass density, and mass has units of distance in geometrized units, so mass density is distance/distance^3=distance^-2.
This means that the units of the stress-energy tensor in SI can't be Newtons, because Newtons are unitless in geometrized units.
Thanks for your response. Newtons^-1 is the dimension of the coefficient of T. If the Ricci tensor has dimension of distance^2, would it not follow that T has dimension N(distance^2)?
My $.02. If you use geometric units, all the coefficients of the stress energy-tensor do have the same dimension if you use a geometric units as defined in "Gravitation" by Misner, Thorne, Wheeler, henceforth MTW. In this setup you measure time in cm, distances in cm, masses in cm. This is so much easier than dealing with different units in the different components of the tensor that it's the way I think about things. BTW, rho would have units of energy / unit volume, which is mass*acceleration*distance/volume, which is cm*(1/cm)*cm / cm^3 = 1 / cm^2, different than your definition which is cm*cm / cm^2. If you need conventional units with the geometric approach, you just stick back the needed values of c and G in your geometric unit result based on a dimensional analysis. Not every author uses this approach though, nothing forces one to do things this way, and any particular text may not adopt this approach.
There's also the issue of whether you are working in a coordinate basis or a "frame-field" non-coordinate basis. The approach I suggest makes more sense in a frame-field basis.
We're really talking about two different issues here: (1) geometrized units versus SI, and (2) units of tensors and their components. Your first two sentences are about #1, your last sentence about #2. They're not related, and really Orodruin and I have just hijacked the thread by having a side discussion about #2.
I have moved the side discussion to a separate thread. Let us continue there and keep this thread on topic.
For clarificatiion:
The stress energy tensor has a coefficient with specific dimensions. In order for the equation to be consistent, T, R and g must have dimensions to make the equation consistent. My understanding of the metric and curvature tensors is that they are geometrical and either have no dimension or (as has been pointed out above) the dimension of distance. In either case, T must have dimensions to make the equation a proper one. N (perhaps with dimensions of distance) seems to have the dimensions to achieve that.
Is this not true?
The dimension of a tensor component (in coordinate basis) is dependent on the dimensions of the coordinate. For example, take a vector V in Cartesian coordinates in two dimensions and transform it to polar coordinates. The components ##V^r## and ##V^\phi## will now have different dimensions. However, if you get the dimensions correct for one component, they will be correct for the rest as well.
How to assign dimensions to a tensor as a whole object is discussed in the thread that was split from this one (see above).
In any units system, the energy-momentum tensor has the unit of energy density, i.e. pressure. So (in 4-dimensional space-time) in powers of Mass, Length and Time [tex][\mathbb{T}] = M L^{-1} T^{-2} .[/tex] You can check that using the definition of the tensor in any field theory [tex]\mathbb{T} \sim \frac{\partial \mathcal{L}}{\partial (\partial \varphi)} \ \partial \varphi - \eta \ \mathcal{L} , \ \Rightarrow \ [\mathbb{T}] = [\mathcal{L}] .[/tex] Or, as you would like to do, from the Einstein field equations [tex]R \sim \frac{G_{N}}{c^{4}} \ \mathbb{T} .[/tex] Notice that [tex]\Gamma \sim g \ \partial g , \ \ \ \ R \sim \partial \Gamma + \Gamma^{2} .[/tex] Since [tex][g] = L^{0} , \ \ \ [\partial] = L^{- 1} ,[/tex] it follows that [tex][\Gamma] = L^{-1} , \ \ \ [R] = L^{-2} .[/tex] You also know the units of Newton’s constant [tex][G_{N}] = M^{-1}L^{3}T^{-2} , \ \ [c]^{4} = L^{4} T^{-4} .[/tex] So [tex][\mathbb{T}] = \frac{[c]^{4} [R]}{[G_{N}]} = M L^{-1}T^{-2} .[/tex] So (in 4-dimensional space-time), if you want to use the natural units where [itex]c = \hbar = 1[/itex], i.e. [itex]L = T = M^{-1}[/itex], you get [itex][\mathbb{T}] = L^{-4} = M^{4}[/itex]. And in the co-called geometric units (again in 4-dimensional space-time): [itex]c = G_{N} = 1[/itex], i.e. [itex]L = T = M[/itex], the energy-momentum tensor will have the same units as the Ricci tensor, [itex][\mathbb{T}] = [R] = L^{-2}= M^{-2}[/itex].
PerpStudent said:
For clarificatiion:
Is this not true?
No, see #3.
Related to Dimension of the stress energy tensor
1. What is the stress energy tensor?
The stress energy tensor is a mathematical object used in the field of physics to describe the distribution of energy and momentum in a physical system. It is a 4x4 matrix that contains information about the energy density, momentum density, and stress of a system.
2. Why is the stress energy tensor important?
The stress energy tensor is important because it is a crucial component of Einstein's theory of general relativity. It is used to describe the curvature of spacetime and how matter and energy interact with it. It is also used in other areas of physics, such as electromagnetism and fluid dynamics, to understand the behavior of physical systems.
3. How is the stress energy tensor calculated?
The stress energy tensor is calculated by taking the energy-momentum tensor, which describes the energy and momentum of a system, and applying a Lorentz transformation to it. This accounts for the effects of relativity and allows for a consistent description of energy and momentum in all reference frames.
4. What are the units of the stress energy tensor?
The units of the stress energy tensor depend on the system being described. In the SI system, the stress energy tensor has units of joules per cubic meter (J/m^3) for energy density, joules per square meter (J/m^2) for momentum density, and joules per cubic meter (J/m^3) for stress.
5. What is the physical interpretation of the stress energy tensor?
The stress energy tensor can be interpreted as a measure of the density and flow of energy and momentum in a physical system. It describes the distribution of these quantities in a given region of space and how they change over time. It is a fundamental concept in understanding the behavior of matter and energy in the universe.
