Does captured light increase a black hole's mass?
In summary, when a black hole captures a photon, its mass-energy increases due to the energy of the photon. The photon loses its identity and becomes a part of the black hole's mass, unable to escape. This is due to the concept of mass-energy in General Relativity, where energy can cause curvature in space-time and increase the gravity of a black hole.
Decimator
30
As energy cannot be created or destroyed, what happens to a black hole that captures a photon? Does the black hole's mass increase by the energy of the photon? Or is the photon simply trapped there, and then escape when the black hole finally evaporates from hawking radiation?
Or something else entirely?
Astronomy news on Phys.org
E=mc2 so yes captured energy does increase a BH's mass
The photon looses its identity upon entering the Black Hole. It is lumped into the Black Hole's mass and will not come out again as itself so far as we know.
Hope that helps :p
Just a comment, General Relativity uses "mass-energy" and a source to cause "curvature" in space-time (or if you like it better this way: a source of "gravity")
Therefore, yes, photons, as they carrying energy, they will increase the mass-energy of the black hole. (and therefore it's gravity)
I can say that the answer to this question is not a simple yes or no. Captured light can contribute to a black hole's mass, but it is not the only factor that determines the mass of a black hole. The mass of a black hole is primarily determined by the amount of matter and energy that it has consumed.
When a black hole captures a photon, its mass does increase by the energy of the photon. This is because, according to Einstein's famous equation E=mc², energy and mass are equivalent and can be converted into each other. Therefore, the energy of the photon adds to the black hole's mass.
However, the captured photon does not simply stay trapped inside the black hole forever. As you mentioned, black holes can emit Hawking radiation, which is a form of radiation that causes the black hole to lose mass over time. This means that eventually, the black hole will lose the energy and mass gained from the captured photon.
It is also worth noting that the increase in mass from a single photon is extremely small and would not significantly impact the overall mass of a black hole. Additionally, the mass of a black hole is not solely determined by the energy it has consumed. Other factors such as the black hole's spin and the gravitational pull of nearby objects also play a role in its mass.
In conclusion, captured light can contribute to a black hole's mass, but it is not the only factor and the mass gained from a single photon is minimal. The photon will eventually escape through Hawking radiation, but the overall mass of the black hole is determined by multiple factors.
FAQ: Does captured light increase a black hole's mass?
How does captured light contribute to a black hole's mass?
When light is captured by a black hole, it adds to the mass of the black hole. This is because light carries energy, and according to Einstein's famous equation E=mc², energy and mass are equivalent. Therefore, the captured light increases the black hole's mass.
Can a black hole gain mass solely from capturing light?
While capturing light does contribute to a black hole's mass, it is not the only way a black hole can gain mass. Black holes can also gain mass through accretion, which is the process of pulling in and absorbing matter from its surroundings.
Does the type or wavelength of the captured light affect the increase in mass?
The type or wavelength of the captured light does not affect the increase in mass of a black hole. All forms of light, whether it is visible light, infrared, ultraviolet, or even radio waves, carry energy and contribute to the mass of a black hole in the same way.
Can captured light ever escape a black hole?
Once light is captured by a black hole, it cannot escape. The gravitational pull of a black hole is so strong that not even light, which has the fastest speed in the universe, can escape it. This is why black holes are often referred to as "light traps".
Does the increase in a black hole's mass affect its gravitational pull?
Yes, the increase in a black hole's mass also increases its gravitational pull. This is because mass and gravity are directly related, and the more mass a black hole has, the stronger its gravitational pull will be. This is why larger black holes have stronger gravitational pulls than smaller ones.
