BenChicago said:w = x = y = z ,
If this were a pump system with water, I think the pressure and flow would be much higher at reading #2, because water has momentum? What about electricity, would the current be higher at #2?
berkeman said:How could the water flow be different at different parts of the uniform-diameter pipe? Water is basically incompressible, so the flow rate has to be uniform in that uniform pipe.
Yes, electricity does have momentum. Momentum is defined as the product of an object's mass and velocity, and electricity is made up of moving electrons which have both mass and velocity.
While electricity itself has no mass, the particles that carry electricity (electrons) do have mass. Therefore, the overall momentum of electricity is determined by the movement and velocity of these particles.
Yes, the momentum of electricity can change depending on the conductor it is passing through. Conductors with higher resistance will slow down the movement of electrons and therefore decrease the overall momentum of electricity.
Yes, the momentum of electricity is affected by the strength of the electrical current. The stronger the current, the more energy is being carried by the electrons and therefore the higher the momentum of electricity.
Yes, electricity can transfer its momentum to other objects. This is known as electrical force and is the basis for how electricity can power machines and devices.
