Does time stop at the singularity?
In summary: No, inside the event horizon, time still exists. However, the coordinate that we label as "time" in the Schwarzschild metric is now the timelike coordinate "r", which means that it points in the direction of increasing time. This can be confusing because we usually think of "r" as a radial distance coordinate. But in this case, inside the event horizon, it is behaving like a time coordinate.
black hole 123
36
In the schwarzschild metric, inside the event horizon the r coordinate becomes timelike, and when when r=0 the coefficient of dr^2 is also 0. So time stops at the singularity, yet somehow it can move around and emit gravitons, i.e. "evolve" even when it's supposed to be frozen like a video that's paused. How?
black hole 123 said:
In the schwarzschild metric, inside the event horizon the r coordinate becomes timelike, and when when r=0 the coefficient of dr^2 is also 0. So time stops at the singularity[...]
There are two problems with your reasoning. (1) Inside the event horizon there is still time. It's just that the timelike coordinate now happens to be the one that we label "r" in the Schwarzschild coordinates. (2) Your reasoning about what happens inside the event horizon doesn't connect logically to your statement about the singularity. The event horizon and the singularity are two separate things.
The word "singularity" means "a place where the mathematical description that we've been using cannot be used because it doesn't correctly describe the physics that's really happening there". The singularity that appears in the Schwarzschild solution is telling us that the Schwarzschild solution describes spacetime in the region ##r\gt{0}##, not ##r\ge{0}##. This, you can't use the Schwarzschild metric as the starting point for reasoning about what happens at ##r=0##.
Furthermore, it is unlikely that the Schwarzschild solution is correct in the region where ##r## is non-zero but very small. The problem that is that it is a vacuum solution; it applies to the vacuum outside of a spherically symmetric mass and it is very unlikely that quantum mechanics will allow us to concentrate the mass in an arbitrarily small spherically symmetric volume. Thus, the Schwarzschild solution should only be trusted in regions where ##r## is large enough that we can ignore quantum mechanical effects and model the matter in the black hole as a perfect fluid.
There's a similar situation in classical physics, one so familiar that you may never have noticed it. You're familiar with Newtonian law that describes the Earth's gravitational field acting on a body of mass ##m##: ##F=GmM_E/r^2##. But did you notice that it has a singularity at ##r=0##? The only reason we don't worry about the absurd result of an infinite gravitational force there is that the Newtonian formula is treating the Earth as an ideal point mass, and we know that that idealization breaks down for ##r\lt{R}_E## where ##R_E## is the radius of the earth.
Likes Imager and fresh_42
This is awfully vague. What is "very small?" Are you referring to the Planck scale?
In general, you appear to be answering a question that the OP didn't ask.
No, when r=0 the metric is undefined, because it has 1/r in two coefficients (g_rr and g_tt). However, that in itself doesn't tell you that there is a physical issue, it just tells you that the coordinates you are using break down. (Note also that there are other coordinate charts in which the coefficient of dr^2 in the metric is perfectly well defined at r = 0.) Coordinates are not physics.
The physical issue is that curvature invariants increase without bound as ##r \rightarrow 0##; that is true independent of your choice of coordinates.
This is a little bit misleading as you state it. Inside the horizon, the Schwarzschild solution is not static; the spherically symmetric mass, outside of which the vacuum exists that the Schwarzschild metric describes, must be either collapsing or expanding, and only the "collapsing" case is relevant if we are considering the future horizon (the "expanding" case is what we get if we extend through the past horizon). What is (probably) very unlikely is that quantum mechanics will allow the mass to collapse into an arbitrarily small volume without some new physics coming into play. But it is not "very unlikely" that QM will allow a static mass inside a horizon to occupy an arbitrarily small volume; that is already impossible at the classical level, regardless of quantum corrections.
That's true... I must confess that I was mostly focused on discouraging the idea of taking the Schwarzschild metric coefficients at face value ib that region.
What do u mean by that? That some region of spacetime has no "time?
FAQ: Does time stop at the singularity?
Does time actually stop at the singularity?
No, time does not stop at the singularity. The concept of time is relative and depends on the observer's perspective. While time may appear to slow down or stop for an outside observer, it continues to pass for an object falling into the singularity.
How does the theory of relativity explain time at the singularity?
The theory of relativity states that time is relative and can be affected by factors such as gravity and velocity. At the singularity, the extreme gravitational pull causes time to slow down significantly, but it does not completely stop.
Is there a point where time completely stops in the universe?
No, there is no known point in the universe where time completely stops. Time may slow down or appear to stop at the singularity, but it does not cease to exist.
What happens to the laws of physics at the singularity?
The laws of physics, including the laws of time, break down at the singularity. This is because the singularity is a point of infinite density and infinite gravity, which is beyond our current understanding of physics.
Can we ever truly understand what happens at the singularity?
It is currently impossible for us to fully understand what happens at the singularity, as our current understanding of physics breaks down at this point. However, scientists continue to research and explore the singularity in hopes of gaining a better understanding of the universe.
