Domain of the composition of these functions
In summary, the domain of the composition of two functions is the set of all inputs that can be used for both functions and result in a valid output. To find the domain, you must determine the individual domains of each function and find the common values. The domain can be different from the individual domains if there are no common values. If an input value is not in the domain, the function composition cannot be evaluated. Considering the domain is important for evaluating all possible input values and understanding the behavior of the composed function.
zeion
466
Form the composition f o g o h and give the domain.
f(x) = x - 1, g(x) = 4x, h(x) = x2
f(g(h(x))) = 4x2-1
The domain of x is any real number.
your answer looks to be correct.
Looks good to me.
You know how to state the range as well?
What is the shape of the graph? Does it have a maximum or minimum?
FAQ: Domain of the composition of these functions
What is the definition of the domain of the composition of two functions?
The domain of the composition of two functions is the set of all inputs that can be used for both functions and result in a valid output. In other words, it is the set of all values that can be plugged into the first function and then the resulting values can be plugged into the second function.
How do you find the domain of the composition of two functions?
To find the domain of the composition of two functions, you must first determine the individual domains of each function. Then, find the values that are common in both domains. These common values will make up the domain of the composition of the two functions.
Can the domain of the composition of two functions be different from the individual domains of each function?
Yes, the domain of the composition of two functions can be different from the individual domains of each function. This can happen when the two functions have different domains and there are no common values between them. In this case, the composition of the two functions may have a smaller domain than each individual function.
What happens if an input value is not in the domain of the composition of two functions?
If an input value is not in the domain of the composition of two functions, it means that the function composition cannot be evaluated for that particular input. This could lead to an undefined or error result, depending on the specific functions being composed.
Why is it important to consider the domain of the composition of two functions?
Considering the domain of the composition of two functions is important because it ensures that the composition can be evaluated for all possible input values. It also helps to identify any potential errors or undefined results that may occur. Additionally, understanding the domain of a function can provide insight into the behavior and characteristics of the composed function.
