Dot product calculates what exactly?
In summary, the scalar product (or dot product) of two vectors is a scalar that is proportional to the length of the projection of the first vector onto the second vector. It has units of square meters and can be used to measure quantities such as energy and torque. The unit vectors used in the calculation are dimensionless.
mjt99
I have a pretty general question about vectors. The scalar product of two vectors is a calculation of what exactly?
For example, if the units of two vectors are meters, the resultant dot product would be a meters squared. So if it's a measurement of area, what area exactly?
I'm very confused about this!
Thanks for the help.
Mathematics news on Phys.org
The scalar product (or dot product) of two vectors is a scalar that is proportional to the length of the projection of the first vector onto the second vector. An example would be a vector A which is 2 units long on the positive x-axis and a vector B which is at a 45 degree angle to the x-axis in the positive y direction with a length of 1. B dot A is then the distance on the x-axis that vector B covers which is 1*cos45. Does that help?
In physics it's the amount of a quantity in a particular direction.
So the dot product of force and direction = work.
I'm still very confused on this topic. In your example above, wouldn't the dot product be:
(1)(2)*cos45
(1)(2)*cos45
You are right. The projection idea is valid when both vectors are of unit length.
Thanks to all for the replies. There's a couple of really good tutorials on this topic on YouTube as well.
You have to be a little careful about what the "units" of a vector are. The length of a vector is in meters, but you can't really say that the vector itself has units of meters. Perhaps a better way to think about it is this:
u.v = (u1i+u2j+u3k).(v1i+v2j+v3k)
= u1v1i.i + u1v2i.j + u1v3i.k + u2u1j.i + u2u2j.j + u2u3j.k + u3u1k.i + u3u2k.j + u3u3k.k
where the coefficients u1, u2, etc are just numbers, and the units are included via the unit vectors i, j, k. In other words, i represents the vector of length 1 meter in the x-direction, j represents the vector of length 1 meter in the y-direction, etc. Then it is taken as a physical principle that i.i = 1 meter, i.j = 0 meter, etc, and the formula becomes
u.v = 1 meter * (u1v1 + u2u2 + u3u3)
I don't think this works as a general principle. If both of the vectors have units of meters, then the dot product should have units of square meters. It's just that these square meters don't happen to measure an area (in a meaningful sense, anyway).
It's a bit more clear what is happening if the two vectors have different units, such as force (kg m / s^2) and distance (m). Then the dot product has units of energy (kg m^2 / s^2), consistent with the definition W = Fd.
Note, however, that torque is also measured in (kg m^2 / s^2)! Just because two quantities are expressed in the same units, does not necessarily mean they are measuring the same thing.
The difference between torque and work is that work measures force times parallel distance, while torque measures force times perpendicular distance.
In the same way, area (m^2) is a measure of distance times perpendicular distance, while the dot product (also m^2) measures distance times parallel distance. It has the units of area, but it is not the same thing as area.
hmm actually you are right it should be square meters. The reason why it is not a problem is that ||x|| = sqrt(x.x). The key being the square root.
The unit vectors are dimensionless.
Suppose [tex]\vec r[/tex] carries units of meters (m),
then
[tex]\hat r \equiv \frac{\vec r}{| \vec r |} = \frac{\vec r}{\sqrt{ \vec r \cdot \vec r}}[/tex]
carries units of [tex] \frac{ [m]} {\sqrt{ [m][m]} }= \frac{ [m]} {\sqrt{ [m]^2} }=1[/tex].
The components carry the units...
[tex]F_x = \vec F \cdot \hat i [/tex] has whatever units [tex]\vec F[/tex] are measured in.
You are correct. Typo ;0)
Welcome to PF!
mjt99 said:
… if the units of two vectors are meters, the resultant dot product would be a meters squared. So if it's a measurement of area, what area exactly?
Hi mjt99! Welcome to PF! :smile:
Yes, the dot product has dimensions of area, but it is a scalar (meaning that dot products obey the scalar law of addition).
As you know, the magnitude of the cross product a x b obviously represents a genuine area, of the parallelogram with sides a and b.
To find an area represented by a.b, think of them as matrices … so one must be a row matrix, and the other a column matrix …
in other words, the dot product is aTb or bTa.
Then one of the vectors is in "transpose space", in which it represents not a vector but a 2-form (or, in n-dimensional space, an (n-1)-form), which is essentially a plane segment (hyperplane segment) of a particular size, perpendicular to the original vector …
then a.b is sort-of aT x b, the area between the vector a and the plane segment bT. :smile:
I don't think this construction works generally.
Suppose we compute aTa... i don't see any meaningful area.
Actually, aT is really a 1-form (here formed with the help of a metric),
which can be visualized by a family of parallel hyperplanes with spacing inversely-proportional to the magnitude of aT. The normals of the hyperplanes are parallel to the vector a, in the case of a Euclidean metric.
The dot-product aTb would then be "the number of http://www.google.com/search?q="bongs+of+a+bell""" for the number of successive hyperplanes of the 1-form aT pierced by the vector b.
(For aTa, we get the squared-magnitude of a: if a is vector of length 4, aT is a family of hyperplanes of spacing 1/4... the vector a pierces 16 hyperplanes of aT.)
The best explanation of the dot product I've read is from the book A Student's Guide to Maxwell's Equations by Daniel Fleisch. Read pages 6-9 to get a fantastically clear explanation behind the physical significance of the dot product. It doesn't require much background. Here is the http://books.google.com/books?id=I-...i=xzvWSZmIFI_EM4-ylPcC&client=safari#PPA6,M1".
If you're interested in working some of the problems from the book using the dot product in electricity and magnetism, the author's http://www4.wittenberg.edu/maxwell/index.html" contains solutions split up into staggered hints and then the full solution.
A useful way to think about the dot-product is as a measure of "overlap".
The "projection" makes this more precise.
FAQ: Dot product calculates what exactly?
What is the definition of dot product?
The dot product, also known as the scalar product or inner product, is a mathematical operation that takes two vectors and produces a single number. It is calculated by multiplying the corresponding components of the two vectors and then adding the products together.
How is the dot product calculated?
The dot product is calculated by taking the sum of the products of the corresponding components of two vectors. This can be done using either the geometric or algebraic method.
What is the purpose of the dot product?
The dot product has several important applications in mathematics and physics. It can be used to calculate the angle between two vectors, determine if two vectors are perpendicular, and project one vector onto another.
What is the geometric interpretation of the dot product?
Geometrically, the dot product can be interpreted as the length of the projection of one vector onto another, multiplied by the length of the other vector. It can also be thought of as a measure of how much two vectors are pointing in the same direction.
What is the relationship between the dot product and vector multiplication?
The dot product is a type of vector multiplication, specifically the inner product. Other types of vector multiplication include the cross product and the outer product. The dot product is used to find the components of one vector in the direction of another vector, while the cross product is used to find a vector that is perpendicular to two given vectors.
