E and B produced by a stationary currrent
  • Thread starter lailola
  • Tags
    produced
In summary: The divergence of the current density \mathbf{J}=I_0 u(t-t_0) \delta(x) \delta(y) \mathbf{e}_z is likewise zero both before and after the switch on.
lailola
46
I have a stationary electric current like this: [itex]\vec{I}=I_0\vec{e_z}[/itex] and I have to calculate the electric and magnetic fields from an inertial frame that is moving with velocity [itex]\vec{v}=v\vec{e_z}[/itex].
First I calculate the vector potential from a rest frame (and then I'll use Maxwell equations to get B and Lorentz transformation for E' and B') and I use cilindrical coordinates, so I get:
[itex]\vec{A}= \frac{\mu _0}{4\pi}∫\frac{dz}{\sqrt{r^2+z^2}}[/itex]
but if I calculate this between -infinity and infinity the integral diverges.
Can this integral be solved? Or, is there an easier way to solve the problem?
Thank you.
Why did you choose to use cylindrical coordinates in a problem that is so clearly rectangular?
I can't see that. Why is the problem clearly rectangular?
Perhaps it's too early in the morning and I haven't had enough coffee yet, but what is a stationary current?
I'm not sure about that but I think it's just a constant current.
Well, the only variation in the problem is with z - everything is independent of x and y. When you use cylindrical coordinates, you introduce a variation in the XY plane that only serves to make the problem more complicated. Or so it seems to me. One question is, "in what direction can the fields point?"
I'm guessing that the current [itex]I[/itex] is confined to the z-axis, and not spread out uniformly over then entire xy-plane.
(Aren't you missing an [itex]I_0[/itex]?:wink:)
The integral indeed diverges. One solution is to extract the finite part of the integral which contains the relevant physics (see here). Another is to calculate the fields directly (not a fun calculation!).
The best method in my opinion is to imagine that the current is turned on at some time [itex]t_0[/itex]. For [itex]t - t_0 <\frac{r}{c}[/itex], the field point will not experience the effect of the current (the fields will not propagate faster than light when the current is switched on). For [itex]t - t_0 > \frac{r}{c}[/itex], the retarded time will only be greater than or equal to [itex]t_0[/itex] where [itex]|z| \leq \sqrt{c^2(t-t_0)^2-r^2}[/itex] (if the retarded time is less than [itex]t_0[/itex], then the fields that arrive at your field point will be from before the current was turned on - that is, they'll be zero). So, it is really only this range that contributes to the integral, as outside, the current [itex]I(t_r)[/itex] is zero.
[tex]\mathbf{A}= \frac{\mu_0 I_0}{4 \pi} \int_{-\sqrt{c^2(t-t_0)^2-r^2}}^{\sqrt{c^2(t-t_0)^2-r^2}} \frac{dz}{r^2+z^2}[/tex]
It's not a good idea to turn on the current abruptly at some finite time since this violates current conservation, and the integral you get cannot solve Maxwell's equations, because these necessarily need a conserved four-current as a constraint, which is closely related to gauge invariance.
I'd simply calculate
[tex]\vec{A}(x)=\frac{\mu_0 I_0}{4 \pi} \int_{-\Lambda}^{\Lambda} \mathrm{d} z \frac{1}{\sqrt{r^2+z^2}}.[/tex]
As you'll then see, for [itex]\Lambda \rightarrow \infty[/itex] you can separate off the divergent part by introducing an arbitrary finite scale [itex]r_0[/itex], upon which no physical quantity, particularly the magnetic field, [itex]\vec{B}=\vec{\nabla} \times \vec{A}[/itex] depends.
This is one of the first encounters of a kind of "regularization and renormalization theory".
Does it? Can you elaborate, because I don't see it.
The amount of charge per unit time moving into any tiny section of wire is the same as the amount of charge per unit time leaving the section of wire, both before and after the current is switched on. In other words, [itex]\frac{\partial \rho}{\partial t}[/itex] is zero both before and after. The divergence of the current density [itex]\mathbf{J}=I_0 u(t-t_0) \delta(x) \delta(y) \mathbf{e}_z[/itex] is likewise zero both before and after the switch on.
What I am not clear on is whether or not this current is a point-source or is it an infinite line of current?
Thank you.
I would assume the current is along an infinitely long wire coincident with the z axis.
Thus the problem becomes degenerate: speed of observing frame irrelevant since its motion is also along the z direction; B invariant with z, i.e. the usual ampere's law formulation about the wire; E zero everywhere except inside the wire.
Yeah, that's what I thought the OP intended but then the calculation for the magnetic field is trivial as you stated.
The Faraday field can be solved for directly using the magnetic field of a straight current carrying wire, suitably made covariant. Geometric algebra makes this very easy to do.
First, we need a way to talk about the part of a vector that is perpendicular to a plane. This is in 4D spacetime, so you can't resort to dot products and normal vectors. You need a wedge product. Let there be a plane [itex]K = a \wedge b[/itex] for two vectors [itex]a,b[/itex]. This is just the plane formed by the span of [itex]a,b[/itex]. For a third vector [itex]s[/itex], the part of [itex]s[/itex] that lies entirely outside of the plane [itex]K[/itex] is denoted by [itex](s \wedge K) \cdot K^{-1}[/itex], where [itex]K^{-1} = K/(K \cdot K)[/itex].
The general form of the Faraday field from a current carrying wire is (in [itex]\mu_0 = \epsilon_0 = c = 1[/itex] units):
[tex]F = \frac{1}{2\pi} I \wedge \rho^{-1}[/tex]
where [itex]I[/itex] is the current vector and [itex]\rho = [s \wedge (I \wedge u)] \cdot (I \wedge u)^{-1}[/itex] for some four-velocity of the wire [itex]u[/itex] and a position vector [itex]s[/itex]. Here's a quick check to ensure this reproduces the stationary current carrying wire: let [itex]I = I_0 e_z[/itex] and [itex]u = e_t[/itex]. Then we have
[tex]I \wedge u = I_0 e_{zt}[/tex]
As well as
[tex]\rho = [(s^\rho e_\rho + s^z e_z + s^t e_t) \wedge (I_0 e_{zt})] \cdot e_{zt}/I_0 = s^\rho I_0 e_{\rho z t} \cdot e_{zt}/I_0 = s^\rho e_\rho[/tex]
Clearly, then, [itex]\rho^{-1} = e_\rho /s^\rho[/itex], and our Faraday field is
[tex]F= \frac{1}{2\pi s^\rho} I_0 e_{z \rho}[/tex]
Exactly as it is in the simple, stationary, infinite current-carrying wire, and since we've done this in terms of arbitrarily oriented wires with arbitrary velocities, we know this solution should hold for all such cases. Note that if the wire goes from carrying no current to carrying some current (that is, the current is a function of time), this method will not hold.
It should be clear that even in the particular case where the boost velocity is parallel to the extent of the wire that an electric field arises and that the magnetic field changes by a factor of gamma. This is seen simply with the transformation [itex]e_z = \gamma (e_{z'} - \beta e_{t'}[/itex], and we get
[tex]F = \frac{1}{2\pi s^\rho} I_0 \gamma (e_{z' \rho} - \beta e_{t' \rho})[/tex]
Which clearly has both electric and magnetic pieces.
FAQ: E and B produced by a stationary currrent
What is the relationship between E and B produced by a stationary current?
The relationship between E and B produced by a stationary current is described by Faraday's law of induction. This law states that a changing magnetic field (B) will induce an electric field (E) in a conductor, and vice versa. In other words, the two fields are interconnected and one cannot exist without the other.
How is the strength of E and B affected by a stationary current?
The strength of E and B produced by a stationary current is directly proportional to the magnitude of the current. This means that the larger the current, the stronger the electric and magnetic fields will be.
Does the direction of the current affect the direction of E and B?
Yes, the direction of the current does affect the direction of E and B. The right-hand rule can be used to determine the direction of the magnetic field produced by a current. This rule states that if you point your thumb in the direction of the current, your fingers will curl in the direction of the magnetic field.
How does distance from the current affect the strength of E and B?
The strength of E and B decreases as the distance from the current increases. This is because the fields are spread out over a larger area, resulting in a weaker overall intensity. This relationship is described by the inverse square law.
Can E and B produced by a stationary current be shielded?
Yes, E and B produced by a stationary current can be shielded by using conductive materials. These materials can redirect the electric and magnetic fields, preventing them from affecting nearby objects. This is commonly used in electronic devices to protect them from external interference.
