Effect of air resistance on angle yielding max displacement
In summary, when considering the effect of air resistance on simple projectile motion, the angle for maximum horizontal displacement may change. In general, the maximum angle would be less than 45 degrees, as it is more favorable to have a higher initial horizontal speed at the expense of hangtime in order to increase range. However, in certain situations, such as at high altitudes, the maximum angle may be greater than 45 degrees due to the thinner air offering less resistance.
sskkiilleeff
Considering simple projectile motion, would the effect of air resistance cause the angle for maximum horizontal displacement to change? Would the maximum angle then be greater or less than 45 degrees? Just a conceptual question, don't really need equations (though wouldn't mind either).
Less. When you factor in air resistance, it becomes favorable to cover proportionally more ground early, while the speed is highest, and hang time becomes less important (because late in the flight, the horizontal speed is substantially decreased anyways). Because of this, a higher initial horizontal speed at the expense of hangtime will increase range compared to a 45 degree shot (assuming only drag and no lifting forces). In other words, a lower angle.
I'm going with - it depends. Back in WWI, the German Paris gun was aimed at something around 50 or 55 degrees to be the maximum range. The explanation was that at high altitudes (45,000 ft and above) the air was thinner and offer less resistance and most of the projectile's flight was above 45k ft. If I remember the article correctly, the angle of flight at 45k ft. was 45 degrees.
For less extreme ballistics, I go with cjl's opinion.
FAQ: Effect of air resistance on angle yielding max displacement
What is the effect of air resistance on the angle yielding maximum displacement?
Air resistance has a significant impact on the angle at which an object will experience its maximum displacement. As air resistance increases, the angle required for maximum displacement decreases.
How does air resistance affect the maximum displacement of an object?
Air resistance acts as a force that opposes the motion of an object. This means that as air resistance increases, the maximum displacement of an object will decrease.
Does the shape of an object affect the impact of air resistance on maximum displacement?
Yes, the shape of an object can greatly influence the impact of air resistance on maximum displacement. Objects with a larger surface area, such as a flat sheet, will experience more air resistance and therefore have a smaller maximum displacement angle compared to a streamlined object.
How can the impact of air resistance on maximum displacement be minimized?
The best way to minimize the impact of air resistance on maximum displacement is to decrease the surface area of the object. This can be achieved by streamlining the shape or reducing the size of the object.
Is there a specific angle that will always yield maximum displacement regardless of air resistance?
No, the angle yielding maximum displacement will vary depending on the level of air resistance. However, in a vacuum where there is no air resistance, the angle of maximum displacement will be 90 degrees.
