Electric field of a loop with one positive halve and one negative halve
In summary, a circular wire with radius R contains a positive and negative line charge on opposite halves. The electric field lines are zero inside the circle and outside the circle, the field is unknown. On the positive z-axis, the electric field only has a component in the z direction. In the x-direction, the field falls off with a power of r^-2. To find the electric field, one must draw a picture and integrate the x-component of the vector contributions from the two opposite charges. The xy and yz planes act as mirror planes, preventing any perpendicular components in the field.
rbnvrw
Given a circular wire with radius R. Choose the origin in the center of the circle, the z-axis perpendicular to the circle. One halve of the circle contains a positive line charge [itex]\lambda[/itex], the other halve a negative line charge of the same magnitude.
(a) Sketch the electric field lines.
(b) Calculate the electric field in a point on the positive z-axis and argument that it contains only a component in the z direction.
(c) What is the direction of the electric field in the x-direction, and with what power of r does this field fall off?
I hope I have correctly translated this from Dutch. ;)
[itex]\vec{E} = \frac{1}{4 \pi \epsilon_0}\int \frac{\hat{r}}{r^2}\lambda dl'[/itex]
(a) I have no idea how to do this. I thought because of the opposing charges the field will be zero inside the circle, outside the circle I haven't got a clue.
(b) For a circle with a uniform line charge it would have been simple, but I get the following result:
[itex]\vec{E} = \frac{1}{4 \pi \epsilon_0}(\lambda \int_{-\frac{\pi}{2}}^{\frac{\pi}{2}} \frac{\hat{r}}{r^2} dl' - \lambda \int_{\frac{\pi}{2}}^{\frac{3\pi}{2}} \frac{\hat{r}}{r^2} dl') = \vec{0}[/itex]
But this can't be correct, right? What am I doing wrong?
(c) I really wouldn't know how to start answering this question. I guess it falls off according to [itex]\frac{1}{r^2}[/itex], but I don't know how to calculate this.
I have my final exam tomorrow, any help would be greatly appreciated!
You need to draw yourself a picture. Include in your picture the vector contributions dE to the electric field from two diametrically opposed points, one with charge +dq and the other with charge -dq. Note that the two arrows do not point in the same direction. So you need to find an expression for the x-component dEx and integrate that to find Ex. Then do a separate calculation to find dEy and from it Ey.
It would be a good idea to choose one of the axes, x or y, such that it goes through the boundaries where the distribution changes sign. This introduces some obvious symmetries about the principal planes, xy, yz and zx.
Thanks for your answer!
So, I tried to draw the contributions. Am I correct that inside the circle the dE due to the negative charge points toward the negative charge and dE due to the positive charge also points in that direction, thus doubling the field? Or is this too naive?
For a point on the z axis, dE due to the positive charge points in the +z direction and towards the negative charge in the xy plane and dE due to the negative charge points in the -z direction also towards the negative charge in the xy plane. Is this correct?
If I have the directions right I think I can calculate the integrals by myself.
Thanks again for your help!
It is not too naive. If the x-axis is the line separating the positive and negative sides, the yz plane is a mirror plane. This means that the field cannot have a component perpendicular to the plane, i.e. in the x-direction.
Also correct. The xy plane is also a mirror plane, therefore there can be no z-component.
Good luck with your integrals.
(a) To sketch the electric field lines, you can use the concept of electric field lines being perpendicular to the equipotential lines. In this case, the equipotential lines would be circles around the center of the wire. Therefore, the electric field lines would be radial lines originating from the positive and negative halves of the wire, as shown in the figure below.
(b) Your calculation for the electric field in a point on the positive z-axis is correct. However, the result is not zero. The electric field at any point on the z-axis will only have a component in the z direction, as there are no charges in the x and y directions. Therefore, the electric field at any point on the z-axis can be given by:
\vec{E} = \frac{1}{4 \pi \epsilon_0}(\lambda \int_{-\frac{\pi}{2}}^{\frac{\pi}{2}} \frac{\hat{z}}{r^2} dl' - \lambda \int_{\frac{\pi}{2}}^{\frac{3\pi}{2}} \frac{\hat{z}}{r^2} dl') = \frac{2\lambda}{4 \pi \epsilon_0} \frac{\hat{z}}{r^2} = \frac{\lambda}{2 \pi \epsilon_0 r^2} \hat{z}
(c) The direction of the electric field in the x-direction can be found by considering the electric field contributions from each half of the wire separately. For the positive half, the electric field will be in the negative x-direction, and for the negative half, the electric field will be in the positive x-direction. Therefore, the total electric field in the x-direction will be zero.
The electric field falls off with a power of r^-2, as can be seen from the expression for the electric field in part (b). This is because the electric field is inversely proportional to the square of the distance from the wire.
I hope this helps! Good luck on your exam tomorrow.
FAQ: Electric field of a loop with one positive halve and one negative halve
What is an electric field?
An electric field is a force field that surrounds an electrically charged object. It describes the strength and direction of the force that would be experienced by another charged object placed in the field.
How is the electric field of a loop with one positive half and one negative half created?
The electric field of a loop with one positive half and one negative half is created by the separation of electric charge. The positive half of the loop has an excess of positive charge, while the negative half has an excess of negative charge. This separation of charge creates an electric field around the loop.
How does the strength of the electric field vary around the loop?
The strength of the electric field around the loop varies depending on the distance from the loop. Close to the loop, the electric field is stronger, and it decreases in strength as you move further away from the loop.
What factors affect the strength of the electric field of a loop?
The strength of the electric field of a loop is affected by the amount of charge on each half of the loop, the distance between the two halves, and the shape of the loop. Additionally, the material surrounding the loop can also affect the strength of the electric field.
How can the direction of the electric field be determined around the loop?
The direction of the electric field around the loop can be determined by the direction of the electric force that would be experienced by a positive test charge placed at different points around the loop. The force would be in the direction of the electric field at that point.
