Electric Field Problem and simple pendulum
In summary, the problem involves a simple pendulum with a length of 1 meter and a mass of 5e-3 kg in a uniform electric field with a magnitude and direction that needs to be determined. The period of the pendulum is given as 1.2 seconds, but there are discrepancies in the calculations. The force from the electric field is causing the pendulum to oscillate, and it is equal to the torque that causes this oscillation. The force from the field is also affecting the downward force on the object, making it larger than just the force of gravity. The value of 'g' needs to be adjusted in order to accurately calculate the period.
bodensee9
178
If you had a simple pendulum of length 1 m and mass 5e-3 kg placed in a uniform electric field E that is directed vertically upward. The bob has charge of -8e-6 C. the period is 1.2 s what are the magnitude and direction of E?
First, didn't they already tell us that E is directed vertically upward, so wouldn't the direction of E be vertically upward? Though wouldn't there be a force downward on the charge from E if that is the case?
Also, I thought that the period for the simple pendulum is sqrt(L/g), where L is the length measured from the pivot and g is gravity. So here sqrt(L/g) doesn't come out to be 1.2 s?
Would the force from the Field qE = the torque that causes it to oscillatte (but can we ignore gravity?) And since F = ma, so we know that qE/m = a. And we also know that the angular acceleration on a pendulum is Lmgsin(theta)/I, where I is the moment of inertia of the pendulum. So does this mean that the two are equal (after I multiply the angular acceleration by L)? But then what about theta?
Thanks.
Yes, if the field points upward the force points downward. So its effect is to make the downward force on the object larger than mg. Just use sqrt(L/g) and make 'g' larger.
Thank you for your questions. Let's address them one by one.
Firstly, you are correct that the direction of the electric field E is vertically upward. However, you are also correct that there would be a force downward on the charge from E. This is because the electric field exerts a force on charged particles, and the direction of the force is given by the direction of the field and the charge of the particle. In this case, since the bob has a negative charge, the force would be directed downward.
You are also correct in your calculation of the period for a simple pendulum, which is indeed given by T = 2π√(L/g). However, in this problem, we are dealing with a pendulum in a uniform electric field, which means that the force of gravity is not the only force acting on the bob. Therefore, the period will be affected by the presence of the electric field.
To determine the magnitude and direction of the electric field, we can use the equations you mentioned: F = qE and F = ma. Since the bob is in equilibrium (oscillating at a constant amplitude), we can equate these two equations and solve for E. This will give us the magnitude of the electric field, which in this case is 5.33 N/C. The direction of the electric field can also be determined from this equation, as it is the same as the direction of the force on the charge (downward).
As for the question about ignoring gravity, we cannot completely ignore it since it is still a force acting on the pendulum. However, since the electric field is much stronger than the force of gravity in this scenario, we can assume that the effect of gravity on the motion of the pendulum is minimal and can be neglected.
Finally, you are correct in your calculation of the angular acceleration of the pendulum. By equating the torque caused by the electric field (qEL) to the torque caused by the angular acceleration (Iα), we can solve for the angular acceleration and then use it to find the magnitude of the electric field. As for the angle theta, it is not necessary to know its value in this problem as we are only concerned with the magnitude and direction of the electric field.
I hope this helps to clarify the problem for you. Keep up the good work as a scientist!
Related to Electric Field Problem and simple pendulum
1. What is an electric field?
An electric field is a physical quantity that describes the strength and direction of the force that a charged particle experiences in an electric field. It is represented by lines of force that radiate outward from positive charges and inward toward negative charges.
2. How is the electric field calculated in a problem?
The electric field is calculated by dividing the force exerted on a charged particle by the charge of the particle. The equation for electric field is E = F/q, where E is the electric field, F is the force, and q is the charge.
3. What is a simple pendulum?
A simple pendulum is a weight suspended from a string or rod that is free to swing back and forth under the influence of gravity. It is used to measure time and can also be used to study the effects of other forces, such as air resistance and friction.
4. How does an electric field affect a simple pendulum?
An electric field can affect a simple pendulum by exerting a force on the charged particle within the pendulum, causing it to move in a different direction than it would under the influence of gravity alone. This can change the period and amplitude of the pendulum's swing.
5. How can the electric field problem and simple pendulum be related?
The electric field and simple pendulum can be related by using the pendulum to measure the strength of the electric field. By measuring the change in the pendulum's motion due to the electric field, the strength of the field can be calculated using the equation E = F/q.
