Electric Potential conducting shell
No, "V" does not have a specific value in this context. It represents the electric potential, which is a measure of the amount of work needed to move a unit of charge from one point to another in an electric field.
suspenc3
402
A thin, spherical, conducting shell of radius R is mounted on an isolating support and charged to a potential of [tex]-V[/tex]. An electron is then fired from point [tex]P[/tex] at a distance [tex]r[/tex] from the center of the shell. [tex](r>>R)[/tex] with an initial speed [tex]v_0[/tex] and directly towards the shell's center. What value of [tex]v_0[/tex] is needed for the electron to just reach the shell before reversing direction?
[tex]\Delta u = \frac{1}{2}mv_0^2[/tex]
[tex]v_0=\sqrt{\frac{2 \Delta u}{m}}[/tex]
Im not sure if this is what I should do, if so, how can I get something for [tex]\Delta u[/tex]
What is the PHYSICS underlying the "relevant equation"?
What does [tex]\Delta u[/tex] mean? and how is it related to the "Electric Potential"?
Conservation of Energy Kinetic Energy + Potential Energy = Constant.
robphy said:
What does Delta u mean? and how is it related to the "Electric Potential"?
Delta U = changes in Potential Energy
= e*V
Regards,
Nacer.
does "V" have a value?
FAQ: Electric Potential conducting shell
What is an electric potential conducting shell?
An electric potential conducting shell is a hollow, metallic structure that surrounds a charged object. It acts as a conductor and can redistribute the electric potential of the charged object to its surface, creating a uniform electric field inside the shell.
How does an electric potential conducting shell work?
An electric potential conducting shell works by redistributing the electric potential of a charged object to its surface. This is achieved through the movement of electrons within the conducting material, which neutralizes any excess charge on the surface of the shell.
What are the properties of an electric potential conducting shell?
The properties of an electric potential conducting shell include its ability to redistribute electric potential, its uniform electric field inside the shell, and its ability to shield any external electric fields from the inside of the shell.
What are the applications of an electric potential conducting shell?
An electric potential conducting shell has many applications in the field of electrostatics. It is used in devices such as capacitors, Van de Graaff generators, and particle accelerators. It is also used in electromagnetic shielding for sensitive electronic equipment.
Are there any limitations to an electric potential conducting shell?
One limitation of an electric potential conducting shell is that it can only redistribute electric potential on its surface. It cannot create or eliminate electric potential. Additionally, the shell must be a perfect conductor with a uniform surface in order to create a uniform electric field inside.
9K
