Electromagnet strength independant of number of turns?
In summary, the magnetic field strength is not constant, but depends on the number of turns of the wire.
dorker
Help me clear up something. I know the magnetic field of an electromagnet's core is given by
where N is the number of turns of wire. Now, the resistance of the wire is given by R = ρ*λ/A, where ρ is the resistivity, and λ the length of the wire. Using Ohm's law to combine them, I get:
But, disregarding the uncoiled ends, the length of the wire can be approximated as λ = n*N, where n is the length of one turn of wire. Replacing this in the last equation makes both Ns disappear, thus suggesting that, at least in steady state, the field strength is independant of the number of turns. Is this correct, or did I make a wrong step somewhere?
If the voltage stays constant you are right. If you double the number of turns you get twice the resistance and therefore half the current. (1/2 * I) * (2 * N) = I*N
No, if the power is constant. Then you can adapt the number of turns so the resistance of the coil matches your needs, that is, the voltage and current available from the power source.
Because as the wire length doubles, the section is halved due the the available room, so the resistance is multiplied by 4, which matches a source of identical power whose voltage is double but current half.
And with half the current in twice as many turns, you get the same magnetomotive force.
Becare this is true in DC or low frequency. At higher frequencies, you have Kelvin effect which prevents using the whole wire section, and much worse, you have eddy currents in the wires which create horrible losses.
Even at 50Hz, this is a constraint, for instance in turbo-generators, where the bars have to consist of several insulated conductors which exchange their positions regularly so current flows everywhere. These conductors are of rectangular section for better filling, and some conductors are hollow for cooling water or hydrogen... and then just a conductor gets a high-tech object.
FAQ: Electromagnet strength independant of number of turns?
What is an electromagnet?
An electromagnet is a type of magnet that is created by an electric current. It consists of a coil of wire wound around a magnetic core, which produces a magnetic field when an electric current is passed through it.
How does the strength of an electromagnet relate to the number of turns in the coil?
The strength of an electromagnet is directly proportional to the number of turns in the coil. This means that as the number of turns increases, the strength of the electromagnet also increases.
Does the material of the core affect the strength of an electromagnet?
Yes, the material of the core can affect the strength of an electromagnet. A core made of a highly magnetic material, such as iron, will result in a stronger electromagnet compared to a core made of a less magnetic material, such as aluminum.
Can the strength of an electromagnet be increased by increasing the current through the coil?
Yes, the strength of an electromagnet can be increased by increasing the current through the coil. This is because the magnetic field produced by an electromagnet is directly proportional to the amount of current passing through the coil.
Is there a limit to how strong an electromagnet can be?
There is no theoretical limit to how strong an electromagnet can be. However, the maximum strength of an electromagnet is limited by factors such as the material of the core, the amount of current that can safely be passed through the coil, and the heat generated by the current.
