Elitzur-Dolev Quantum Liar Paradox
In summary, this experiment tests whether or not particles can be in two mutually exclusive states at the same time. If they can, it's a paradox because it means one of the particles must interact with a traversing photon.
Quantum of Solace
I've seen Elitzur's brief presentations on this. Two excited atoms pointed at a detector. The detector goes off, it isn't known which particle fired the photon, so you interrogate one, it gives a definite answer but violates bell's inequality? I'm sorry but I'm lost at such a vague description and this was the best I could find. What is the logic behind this test? I appreciate any references you could offer.
Quantum of Solace said:
I've seen Elitzur's brief presentations on this...
Do you have a reference? Without that, it's going to be hard for anyone to comment sensibly.
Likes bhobba and vanhees71
A quick google search found, well, this very thread. But also these slides:
Screenshot from 2016-07-28 11:53:04.png
Basically it's describing this quantum circuit, where a parity measurement creates entanglement between two qubits that start off separable:
Screenshot from 2016-07-28 11:56:41.png
This is an example of "performing a measurement forces the system into the state indicated by the measurement outcome, even if that state is entangled and you feel like that's weird".
This particular setup works on inputs that are in X-axis states (e.g. On+Off), but not Z-axis states (e.g. just On). Doing an X-axis or Y-axis parity measurement in addition to the Z-axis parity measurement would fix that, but kinda breaks the analogy with the simple physical system. With both parity measurements it's a full fledged Bell basis measurement, which must force the system into one of the Bell basis states (and tell you which one). All of those basis states are fully entangled, so the output is entangled.
It took a while, but I finally found the reference:
http://a-c-elitzur.co.il/uploads/articlesdocs/MultipleIFM.pdf
Section 10, Page 13 "The Quantum Liar Paradox"
Still trying to understand this properly, but it seems to me until the Z measurement (which box?) is performed, each particle Z exists in the blocking(or non blocking) box only as part of a superposed state, and is thus not forced to interact with the photon, leaving it to interfere with itself.
If two entangled particles have a 50% chance of being in the "blocking" box, (mutually exclusive), does that mean one of them MUST interact with a traversing photon? or does quantum mechanics allow a possibility for photons to traverse both boxes? If so, then I'm not sure I get why this is supposed to be a paradox.
FAQ: Elitzur-Dolev Quantum Liar Paradox
What is the Elitzur-Dolev Quantum Liar Paradox?
The Elitzur-Dolev Quantum Liar Paradox is a thought experiment that highlights the strange behavior of quantum particles. It involves a photon passing through a half-silvered mirror and a detector that can either be set to detect the photon, or to not detect it. The paradox arises when the detector is set to not detect the photon, but the photon is still somehow detected.
How does the Elitzur-Dolev Quantum Liar Paradox challenge our understanding of reality?
This paradox challenges our understanding of reality because it suggests that the mere act of observing a quantum particle can change its behavior. In traditional physics, the act of observation does not affect the behavior of particles. However, in quantum mechanics, the observer has an active role in determining the outcome of a quantum system.
What is the significance of the Elitzur-Dolev Quantum Liar Paradox in the field of quantum mechanics?
The Elitzur-Dolev Quantum Liar Paradox is significant because it highlights the concept of superposition, which is a fundamental principle in quantum mechanics. Superposition refers to the ability of a quantum system to exist in multiple states simultaneously. This paradox also raises questions about the role of the observer in quantum systems and the nature of reality.
Is the Elitzur-Dolev Quantum Liar Paradox a real-world phenomenon?
No, the Elitzur-Dolev Quantum Liar Paradox is a thought experiment and has not been observed in the real world. However, similar experiments have been conducted to demonstrate the principles behind this paradox, such as the famous double-slit experiment.
How can the Elitzur-Dolev Quantum Liar Paradox be resolved?
There is no clear resolution to the Elitzur-Dolev Quantum Liar Paradox, as it is still a subject of debate among scientists. Some suggest that the act of measurement or observation causes the collapse of the quantum state, while others propose alternate interpretations of quantum mechanics. Further research and experimentation are needed to fully understand this paradox and its implications.
