Energy of a single-domain particle in a B-field
In summary, the conversation discusses the energy of a single-domain particle in an external magnetic field, including factors such as the Zeeman energy, demagnetizing factor, and anisotropic energy. The formula for calculating this energy is provided as -½*μ0*H*χ - μ0*μ*B*cos(θ) - K*V*sin^2(θ).
HappyJazz
As seen here, http://homes.nano.aau.dk/ld/EOM15.pdf (last page):
"Now a 1-domain paricle is placed in a magnetic field B in the z direction. The magnetization M of the particle points in a direction with an angle θ to the z-axis. The particle has volume V.
I've solved the first part, determining the energy of a single-domain particle (no B-field) and a 2-domain particle (also no B-field). However, now that the 1-domain particle is placed in an external field the case is another.
I've set the energy equal to:
"magnetostatic energy" + "energy from the dipole / field interaction (-µ * B * number of magnetic dipoles * cos(theta))" + "anisotropic energy since the field is not parallel with the magnetization"
You can see the formula attached in the gif. However, it just looks wrong to me, and I feel I've somehow forgot something very important
Your attempt at a solution is on the right track, but there are a few things that should be clarified. First of all, the formula you have attached is not complete. The energy of a single-domain particle in an external magnetic field should also include the Zeeman energy, which is the energy associated with the interaction between the magnetic moment of the particle and the external magnetic field. This can be expressed as -μ0*μ*B*cos(θ), where μ0 is the permeability of free space, μ is the magnetic moment of the particle, B is the magnetic field strength, and θ is the angle between the magnetic moment and the magnetic field.
Additionally, the magnetostatic energy should be calculated using the demagnetizing factor, which takes into account the shape and size of the particle. This can be expressed as -½*μ0*H*χ, where H is the applied magnetic field strength and χ is the demagnetizing factor.
Finally, the anisotropic energy term should also be included, as you have mentioned. This takes into account the anisotropy of the material, which affects the direction of the magnetic moment. This can be expressed as -K*V*sin^2(θ), where K is the anisotropy constant and V is the volume of the particle.
Therefore, the complete formula for the energy of a single-domain particle in an external magnetic field is:
E = -½*μ0*H*χ - μ0*μ*B*cos(θ) - K*V*sin^2(θ)
I hope this helps clarify any confusion you may have had. Good luck with your calculations!
FAQ: Energy of a single-domain particle in a B-field
What is a single-domain particle?
A single-domain particle is a type of magnetic particle that has a uniform magnetization direction throughout its entire volume. It is typically small in size, on the order of nanometers, and has a high magnetic anisotropy, meaning it prefers to align its magnetic moment in a specific direction.
What is a B-field?
A B-field, also known as a magnetic field, is a region in space where a magnetic force can be detected. It is created by moving electric charges and can exert a force on other moving charges or on magnetic materials such as single-domain particles.
How does a B-field affect the energy of a single-domain particle?
A single-domain particle in a B-field will experience a torque, or twisting force, due to the interaction between its magnetic moment and the B-field. This torque will cause the particle to rotate, resulting in a change in its energy as it aligns with the B-field.
What is the relationship between the B-field strength and the energy of a single-domain particle?
The energy of a single-domain particle in a B-field is directly proportional to the strength of the B-field. As the B-field increases, so does the energy of the particle. This relationship is described by the equation E = -μ•B, where E is the energy, μ is the magnetic moment of the particle, and B is the B-field strength.
What factors can influence the energy of a single-domain particle in a B-field?
The energy of a single-domain particle in a B-field can be influenced by various factors such as the strength and direction of the B-field, the size and shape of the particle, and the material properties of the particle. Additionally, external factors such as temperature and applied stresses can also impact the energy of the particle.
