Energy shift using perturbation theory
In summary, to find the energy shift of a hydrogen atom due to a relativistic correction, you need to take the matrix element of the perturbation over unperturbed wave functions and integrate the result over all space. The unperturbed wave functions can be found by searching online.
captainjack2000
99
I am looking at the relativistic correction to the kinetic energy for a hydrogen atom. I am told that the perturbation is usually written as
H = -p^4/(8 m^3 c^2)
and need to find the energy shift
I know that from the perturbation theory the energy shift is given by
delta E = <n|H|n>
From the unperturbed hamiltonian
p^2 / (2m) = En - V
so we can rewrite the perturbation in terms of En and V
The part I am not sure about is how to approach the wavefunctions n? Normally we have to solve an integral...what do I use as wavefunctions?
thanks
You want to take the matrix element of the perturbation over unperturbed wave functions. The unperturbed wave functions are the hydrogen atom wave functions without the perturbation. You can look them up on Wikipedia or Google them. So to find the energy shift of the ground state, for example, you need to apply the perturbation to the unperturbed ground state, then multiply be the complex conjugate of the unperturbed ground state, and integrate the result over all space. Does this answer your question?
FAQ: Energy shift using perturbation theory
What is perturbation theory?
Perturbation theory is a mathematical method used to approximate solutions to a complex problem by breaking it down into simpler, solvable components. It is commonly used in physics and chemistry to study systems that are difficult to solve exactly.
How does perturbation theory relate to energy shifts?
In the context of energy shifts, perturbation theory is used to calculate the change in energy levels of a system when it is slightly disturbed or perturbed by an external force or interaction. This allows us to better understand the behavior of the system and make predictions about its response to external influences.
What are some common applications of perturbation theory in energy shift calculations?
Perturbation theory is commonly used in quantum mechanics to study the energy levels of atoms and molecules. It is also used in solid state physics to study the behavior of electrons in a crystalline lattice. Additionally, it has applications in nuclear physics, where it is used to calculate the energy levels of nuclei.
What are the limitations of perturbation theory in energy shift calculations?
Perturbation theory is most effective when the perturbation is small and the system can be broken down into solvable components. If the perturbation is too large, the approximations made in perturbation theory may no longer be accurate. Additionally, perturbation theory may not be applicable to systems with strong interactions or non-linear behavior.
How is perturbation theory used in conjunction with other methods to study energy shifts?
In many cases, perturbation theory is used in combination with other methods, such as variational methods or numerical calculations, to improve the accuracy of energy shift calculations. Perturbation theory can also be used to validate the results obtained from other methods and provide a deeper understanding of the underlying physical principles at play.
