Equation for this graph - Mathematica
In summary, an equation for a graph in Mathematica is a mathematical expression that describes the relationship between two or more variables. To create an equation for a graph in Mathematica, you can use the "Plot" function and specify the mathematical expression you want to graph. You can manipulate the equation for a graph in Mathematica using functions such as "Manipulate" or "Animate". The equation for a graph in Mathematica can be exported using the "Export" function. There are also methods to find the equation for a graph in Mathematica, such as using the "Fit" or "FindFormula" function.
caleytm
I think its a variation of a cosine function, but i have no idea what
Does anybody have any idea?
y = 1 + (cos(x) + 1)^2 is a fair fit.
FAQ: Equation for this graph - Mathematica
What is an equation for a graph in Mathematica?
An equation for a graph in Mathematica is a mathematical expression that describes the relationship between two or more variables. It is typically written in the form of y = f(x), where y is the dependent variable and x is the independent variable.
How do I create an equation for a graph in Mathematica?
To create an equation for a graph in Mathematica, you can use the "Plot" function and specify the mathematical expression you want to graph. For example, if you want to graph the function y = x^2, you would use the command Plot[x^2, {x, 0, 5}]. This will create a graph of the function from x = 0 to x = 5.
Can I manipulate the equation for a graph in Mathematica?
Yes, you can manipulate the equation for a graph in Mathematica by using various functions such as "Manipulate" or "Animate". These functions allow you to change the values of the variables in your equation and see how it affects the graph in real time.
How can I export the equation for a graph in Mathematica?
You can export the equation for a graph in Mathematica by using the "Export" function. This will allow you to save your equation as an image or a text file that can be used in other programs or documents.
Is there a way to find the equation for a graph in Mathematica?
Yes, there are several methods to find the equation for a graph in Mathematica. One way is to use the "Fit" function, which will fit a mathematical expression to a set of data points on a graph. Another way is to use the "FindFormula" function, which will attempt to find a simple formula that describes the data on the graph.
