ramstin
- 18
What would be the easiest way to find a length of a side of a triangle using its angles, with one length of a side given.
The equation for finding the third angle in a triangle is: third angle = 180 degrees - (first angle + second angle).
To find the missing side length in a triangle using angles, you can use the Law of Cosines: c^2 = a^2 + b^2 - 2ab*cos(C), where c is the missing side length, a and b are the known side lengths, and C is the angle opposite the missing side.
Yes, you can use the Law of Sines to find the missing side length in a triangle. The formula is: sin(A)/a = sin(B)/b = sin(C)/c, where A, B, and C are the angles and a, b, and c are the corresponding side lengths.
No, it is not possible to have a triangle with three right angles. The sum of the interior angles in a triangle is always 180 degrees, so if one angle is 90 degrees (a right angle), the other two angles must add up to 90 degrees.
You need at least three equations to solve a triangle using angles and side lengths. These can be the Law of Cosines, the Law of Sines, and the equation for the sum of interior angles (180 degrees).
