Equilibrium using angular momentum
In summary: Thanks for checking.In summary, the tension in the cable is needed to keep the beam in place. The minimum coefficient of static friction between the beam and the floor is required for the beam to remain in this position.
alco19357
A uniform, 210-kg beam is supported by a cable connected to the ceiling, as shown in the figure . The lower end of the beam rests on the floor.
a. What is the tension in the cable?
b. What is the minimum coefficient of static friction between the beam and the floor required for the beam to remain in this position?
[itex]\Sigma[/itex]F_x = 0
[itex]\Sigma[/itex]F_y = 0
[itex]\Sigma[/itex]Torque = 0
So we draw a free body diagram for both the beam and cable. I have 4 forces (perhaps I'm wrong with how many forces I actually have)
I have a normal x and y force on the ground acting on the beam.
I have gravity acting on the beam. I have tension acting on the beam. And that's all I believe.
So I get N_x + Tcos40 = F_x
and... N_y + Tsin40 = F_y
and... Torque = T*cos160*r - mgcos40 << the length of the beam isn't given though?
Please help
Think again about the angle 40 inTsin40 and Tcos40.
I do not think the angle is 40.
grzz, thanks for the reply
I don't understand how it's not 40.
Isn't there a force, T that the beam exerts back on the cable? Shouldn't those forces be opposite but equal?
I am assuming that your x-dir is the horizontal direction. So the angle between the Tension T in cable and the horizontal is 60.
Okay I see that.
Now I got: (R is the reactionary normal force of the ground, w is weight, L is length of the beam)
R_x + Tcos60 = 0
R_y + Tsin60 - w = 0
T_1 = -L/2 * W * sin130 (counter clockwise is +)
T_2 = L*T*sin160
Are these two tensions right?
If so, I'll have three equations
1. R_x + Tcos60 = 0
2. R_y + Tsin60 - w = 0
3. L*T*sin160 - L/2 * W * sin130 = 0
Then I assume solve for t
Rx and tcos60 must be in opp dir for equilib
T_2 = L*T*sin160
Try to use acute angles. i cannot follow what you mean by the above equations.
Thanks for the help,
I got T = 2300
Now for part b though, I would think the coefficient should be u=f/N
f is R_x
N is R_y
R_y + Tsin60 - W = 0
R_y = W - Tsin60
...= 210*9.8 - 2300*sin60
...= 66.14157
R_x - Tcos60 = 0
R_x = Tcos60
...= 2300*cos60
...= 1150.000
u = f/N
u = R_x / R_y
u = 1150 / 66.14
u = 17.38736 to 2 sig figs... = 17
but it says its wrong?
How did you get the value of T?
LT*sin160 - .5*L*W*sin130 = SUM OF TORQUES = 0
LT*sin160 = .5*L*W*sin130
T = .5 * W * (sin130)/(sin160)
The website said that was the right answer
yes tension is Ok
Did I do everything right to find the coefficient of kinetic friction then? wWhere did I go wrong in that solution
thanks
Are you sure the weight of the beam is 210kg?
Yes, I think the book didn't use the rounded answer for the tension force when they calculated the normal force. Hence, they would get an answer around like 18.5 or so
The coefficient of friction CAN have a value greater than 1. But a value close to 17 appears to me to be unusually a high value. But I checked your work again and could not find any mistake, neither in Physics nor in Mathematics.
Of course I could have made a mistake myself!
FAQ: Equilibrium using angular momentum
What is angular momentum?
Angular momentum is a physical quantity that measures the amount of rotational motion of an object. It is a vector quantity, meaning it has both magnitude and direction, and is defined as the product of an object's moment of inertia and its angular velocity.
How is angular momentum conserved in equilibrium?
In equilibrium, the total angular momentum of a system remains constant. This means that the sum of the angular momenta of all the objects in the system does not change, even if individual objects are rotating or moving. This conservation of angular momentum is a fundamental law of physics.
What is the equation for calculating angular momentum?
The equation for angular momentum is L = Iω, where L represents angular momentum, I represents moment of inertia, and ω represents angular velocity. The unit of angular momentum is kilogram-meter squared per second (kg·m^2/s).
How does changing the moment of inertia affect angular momentum?
As the moment of inertia of an object increases, its angular momentum also increases. This is because the object becomes more difficult to rotate due to its increased mass or distribution of mass. Conversely, decreasing the moment of inertia will decrease the object's angular momentum.
Can angular momentum be transferred between objects in equilibrium?
Yes, angular momentum can be transferred between objects in equilibrium. This can occur through collisions or other interactions between objects. However, the total angular momentum of the system will remain constant, meaning that any increase in one object's angular momentum will be offset by a decrease in another object's angular momentum.
